Delay in fuel pump relay when turn the key. .. Won't start til relay switches - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Delay in fuel pump relay when turn the key. .. Won't start til relay switches
Unread 08-24-2011, 05:14 PM   #16
leandro171
Worked Great !!!!!
For some reason mines had two 220uf and one 470uf capacitors. Could be year related mines is a 92 wrangler
leandro171 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2011, 07:26 PM   #17
oldtime_ironman
Originally Posted by fisherman125 View Post
It worked perfectly!!! Fired on the first try and everytime since took about ab hour make sure when you buy the caps at radio shack that you but a fine tip soldering iron and a solder sucker oh and you don't need a part number they are a common cap 220 uf 35 vdc electrilitic radial leads
Congratulations, you just saved your self a couple hundred bucks! The bad electrolytic caps were a problem throughout the entire electronics industry back then, they were traced to factories in Malasia and Taiwan. Lots of people paid big $$$ and there were lawsuits and warranty repairs. Dell computers got bit hard by it.
oldtime_ironman is offline   Reply With Quote Quick reply to this message
