Definitive Rear Shackle Lift - JeepForum.com
post #1 of 5 Old 08-29-2004, 08:51 AM Thread Starter
prossett
prossett's Avatar
Location: The oasis city of Al Ain, where the red sand dunes of the UAE meet the craggy mountains of Oman
With all due respect to MDEnce who posted:
When you are ready, do the back first.
Put the JEEP on jack stands and drop the gas tank skid. Just take the nuts of the short bolts on the rear of the gas tank skid. (The prior tip about removing the bushings can work too.)
Then lossen the shackle bolts, top and bottom. I used a box wrench behind and a tire iron in front, worked great.
You can then put a scissor jack, or bottle jack between the top of your leaf's and the frame and jack it so that you can slide the bolts out (if it's stuck, a long screwdriver and a hammer will help).
Then replace the old shackle with the new one.
Adjust the jack and replace the bolts (with new GRADED ones)
Put the replacement bolt in the opposite way from when you removed them so you don't have the gas tank interference problem if you do this again.
Do the other side the same way.
Now bolt your gas tank skid back up.
This looks like the simplest, most efficient method of removing the rear shackles - is this then THE way to do it?
If so, it should go in the FAQ for posterity (credit to MDEnce of course)
I just did my front two and tomorrow I tackle the back: to my untrained eye it looks like dropping the skid is not going to give enough room to slide the bolt out.
Other two alternatives I've found on search are: cut the bolts off, remove the outside half of the bushing.
International Jeep Club, Member No. 1 - Canadian living in the United Arab Emirates
White Jeep Club Member 33
prossett is offline
post #2 of 5 Old 08-29-2004, 06:39 PM
ncjeepinyj
ncjeepinyj's Avatar
I cut my bolts, but later had a frient tell me that he was able to get his out by removing the bushing. If i had it to do over again, i would try the bushing first.
ncjeepinyj is offline
post #3 of 5 Old 08-29-2004, 06:47 PM
Shinner
Shinner's Avatar
Bushings are the way to go....no bolt cutting, no gas tank drop. Piece of cake.
His : 1992 YJ (Almighty 4 banger)
Hers: 2004 WJ Columbia Edition (4.7HO)
- Black Jeep Club V2.0 #37
- Merry Wacko Jeep Club #37 - Metalhead Jeep Club #37 - 2.5L Low Output Jeep Club #37
Shinner is offline
post #4 of 5 Old 08-29-2004, 10:09 PM
MDEnce
MDEnce's Avatar
Hey, I wasn't looking for credit or anything, just trying to give back to the forum that has been a help to me.
As far as THE way, like I said I've heard the bushing removal thing will work too (and it loooks like it would). Since I wouldn't re-use the bolts, I'd have just cut them off if I had a working grinder (but I wasn't gonna try it w/just a Dremmel)
From my own experience, I've done the tank skid, twice, on my 95 YJ and there is enough room.
Let us know which way you ended up trying, and how it went.
Good luck.
95 YJ Rio Grande 2.5L I4 5-speed
Got some stuff - always need more stuff
WHITE Jeep Club Member #95
97 XJ Sport 4.0L I6 Auto
Wife's Jeep - 2" budget boost and 31" BFG AT's
MDEnce is offline
post #5 of 5 Old 08-30-2004, 04:05 AM Thread Starter
prossett
prossett's Avatar
Mission accomplished - dropped the skid and slipped out the bolts with very little cursing!
It was actually very simple. No bolts were stuck (pre-soaked) and the jack opened up the leaf enough to reach the new shackle.
The bushings looked cracked and I thought I had to replace them, but no, they were fine and still plenty to go. This is on a 93 I6. I assume that the dry desert air is good for fasteners and bushings.
As for our friend MDEnce, I know you weren't looking for credit, but credit is due - certainly not for inventing this method but at least for sharing it.
I think it should be added to the FAQ, since a lot of questions go up about those rear shackle bolts. Instead of starting a whole new message there, I notice that Sentinal02 has editing rights on his message of where he lists different kinds of lift, including the shackle lift. I'll PM him and see if he wants to add the three methods of dealing with the rear bolts.
prossett is offline
Definitive list of 15" wheels that will fit JK?! redrockin7 JK Wrangler Technical Forum 68 09-24-2016 09:32 AM
Definitive language on Warranty sromain JK Wrangler Technical Forum 4 06-29-2008 03:06 PM
can't find a definitive answer to this question?? blacktjsport TJ Wrangler Technical Forum 4 12-14-2005 11:51 AM
need definitive answer on backspacing derby TJ Wrangler Technical Forum 3 11-20-2002 03:17 PM
The definitive guide to the Jeep Wave Bob K YJ Wrangler Technical Forum 0 02-14-2002 09:02 PM
