Deepwoods INC. Hard Top - JeepForum.com
post #1 of 12 Old 10-07-2009, 04:22 PM Thread Starter
evercoleman
I got this hard top with my yj and I don't believe its ever been mounted on this jeep. I cant find any information on this manufacture. It has a sticker on the inside of the rear glass that says Deepwoods Inc. Will i need the rubber pieces for the corners of the windshield and my upper door which matches the top doesnt seem to line up right at all. they are fiberglass uppers with slider windows
evercoleman is offline
post #2 of 12 Old 10-07-2009, 05:40 PM
Louie4
Take a pic. Someone might have something similar and not know the brand name.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 12 Old 11-19-2010, 05:24 PM Thread Starter
evercoleman
Can someone help me please identify this hard top, I believe it was made for a cj-7. The rear glas has a long piano hinge across the top instead of the two seperate hinges. Also on the sticker inside the lift gate it says it was made by deepwoods inc. in Oneida TN. I cant find any info on this company. I was also wondering how i should attach it to the windshielf frame and if I need the rubber corner seals?>??? Any help would be greatly appreciated
post #4 of 12 Old 11-19-2010, 07:33 PM
50rck
It almost looks like a JCWhitney top I had for mine when I was in college. I sold the top with another Jeep and kept the old CJ top I had. But that is similar to it. Does the back window have two latches? One on either side? I ask because the CJ factory top I kept had one handle in the middle, that operated the two latches on either side, but the JCWhitney top had a handle on either side. If that makes sense
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #5 of 12 Old 11-19-2010, 08:30 PM
southbound
I did a quick Google search and a Mulch company in VA pops up with that name. A business directory in Oneida, TN had this:
deepwoods inc. - deepwoodsinc.com - oneida, TN Business
I think one of the PO's may have worked for this company and slapped the sticker on the glass. I don't think it has anything to do with the actual top.
Or maybe it was a company that did manufacture Jeep hard tops and has since went out of business, so these guys took the name. Highly unlikely, but I guess it's possible .
Can you snap a picture of that rear hinge for the lift gate? I would like to see that. The only ones I have ever seen have had the two hinges on either side.
southbound is offline
post #6 of 12 Old 11-19-2010, 08:40 PM
timatoe
timatoe's Avatar
The corners should be really close to factory so, I'd just order up a set of those seals. For mounting the top I'd suggest one of these... Kwick Kit
timatoe is offline
post #7 of 12 Old 11-19-2010, 08:56 PM
southbound
I've always thought the Kwik kits were a bit over priced. You can pick up those latches at most hardware stores for a few bucks a piece. I found a couple a few weeks back when I was thinking of going with that method of attaching the hardtop to the windshield. It would save you some cash to spend on those corner seals (which usually run a little over $10 a piece).
post #8 of 12 Old 11-19-2010, 09:34 PM
cwjeep
that looks exacly like my acme top.
cwjeep is offline
post #9 of 12 Old 11-19-2010, 09:55 PM
cwjeep
it is cj-7 top
cwjeep is offline
post #10 of 12 Old 11-20-2010, 03:54 PM
Mazdarx
It might have been made for a Cj7 but it's not an original Cj7 top thats for sure.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #11 of 12 Old 01-25-2013, 12:12 PM
lileuroimport
Deep Wood Jeep tops
Deep Woods was in Oneida TN and was a small company that made jeep , suzuki, tracker Tops, doors etc back in the mid to late 90s. There was also another company called Fleet air and Creative Glass Works also in Oneida at the same time making all kinds of Fiberglass parts for all kinds of Cars, trucks etc.
Im located about 40 miles from Oneida and trade on Jeep wrangler , Land Rover Discovery and other Rare and Classic European Imports . 931-349-4480
lileuroimport is offline
post #12 of 12 Old 09-12-2013, 02:02 AM
nibgoyar
deepwoods jeep top
I used to work for the company they are located in onida tn or Winfield tn owners name is or was larry waters hope that helps.
nibgoyar is offline
Hard Top - Hard Doors Improvised Rattle solving thread bparsel YJ Wrangler Technical Forum 7 07-22-2009 07:23 PM
Half Hard Doors vs Full Hard....Key Cylinders Swappable? Hunta TJ Wrangler Technical Forum 17 05-13-2009 02:57 PM
hard half doors/sliding windows/hard top tomthbomb YJ Wrangler Technical Forum 7 07-13-2007 07:42 PM
Who Sells Hard Door Inserts that match the Hard Top gtospeeding TJ Wrangler Technical Forum 7 05-06-2007 10:15 AM
DeepWoods Hardtops yman2or YJ Wrangler Technical Forum 0 02-09-2004 05:24 PM
