Deep auto trans pan - JeepForum.com
post #1 of 7 Old 04-17-2010, 06:17 AM Thread Starter
Robbypfd
Deep auto trans pan
Last year I moved the vent up on the trans and this year I was thinking about putting a deep pan on it. I have a TJ exhaust pipe on it so I dont have to worry about that going under the pan and there is enough room for one between the trans and the skidrow skid plate. I see lots for the newer TJs, but none for YJs. I have a 93 with the 4.0
Thanks for any help
Rob
Robbypfd is offline
post #2 of 7 Old 04-17-2010, 11:47 AM
notmyj
I think your money would be better spent on a trans fluid cooler.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #3 of 7 Old 04-17-2010, 12:52 PM
I8AHUMR
I did this mod. The 32rh/999 pan for a tj is the same as for the yj. I got mine from summit.
The 32rh/999/904 all have the same pan
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #4 of 7 Old 04-17-2010, 03:47 PM Thread Starter
Robbypfd
Thanks for the reply. I already have a trans cooler and the trans vent relocated so it up to the underside of the hood, but I wanted a deep pan for extra fluid when going up steep inclines. I will check into one the from summit.
Thanks again
Rob
Robbypfd is offline
post #5 of 7 Old 03-02-2014, 02:24 PM
DZINE
1997 XJ Cherokee
Thanks again
Rob
if your still looking for a AW4 deep trans pan, ( yourcovers.com ) has had multiple request for them but sais due to the dipstick being part of the pan it makes it difficult/ and expensive to construct a deep pan. They do say if they receive 50 or more requests for AW4 deep pans they will make them, curently they have 10.
So get the word out lol
DZINE is offline
post #6 of 7 Old 03-02-2014, 10:41 PM
deathtrap
If you want to save a few greenbacks, you can get a pan off a 42Re trans used in zjs , Dakota trucks, and some full sized vans, it's about 2 inches deeper and has the same bolt pattern. Pretty easy to find at the junk yards.
deathtrap is offline
post #7 of 7 Old 03-04-2014, 01:24 PM
XJ93
Just don't forget to get the longer tubed filter guys, some people do really need to be told that.. SMH.
XJ93 is offline
Is it easy to swap out my 3speed auto trans for the 4speed auto trans? bhicks TJ Wrangler Technical Forum 15 08-30-2010 09:30 AM
Deep water crossings with auto trans skipilot YJ Wrangler Technical Forum 7 12-28-2009 03:33 PM
Skyjacker Deep Trans pan UTWeezul TJ Wrangler Technical Forum 8 11-21-2008 09:06 PM
deep auto pan rmack TJ Wrangler Technical Forum 7 04-19-2008 09:18 PM
Deep Sump Trans Pan safarimike TJ Wrangler Technical Forum 3 01-30-2007 08:23 PM
