Death wobble, sway bar??? - Page 2 - JeepForum.com
post #16 of 35 Old 04-12-2013, 11:45 AM
Jax89Jeeper
With all new components and an oscillation at the wheels, the damper fixed the problem.... no more oscillation. In what way does the DW still exist if the oscillation is gone? The SS is an engineered part of the system, the designers added it because it was needed. The DW is gone, it is not hidden, it is taken care of by the design of the system. We live in an imperfect world so even with all new components the SS is still needed to make up for that imperfection.
Jax89Jeeper is offline
post #17 of 35 Old 04-12-2013, 11:53 AM
Kodiak17
Its not gone, you just can't feel it. Theres still a loose end somewhere. And it wasn't added because it was needed, you can drive without an SS.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #18 of 35 Old 04-12-2013, 12:13 PM
squishy
Agreed. It's not gone. Your front end is messed up somewhere. The SS is like track bars with leaf springs USELESS!!!!
squishy is offline
post #19 of 35 Old 04-12-2013, 01:41 PM
Siva283
If it is only doing it in the small speed range the first thing you should do is have your tires balanced. In YJ's that more often than not is the cause. It is rare for our leaf sprung YJ's to get real death wobble. As Squishy said our YJ's dont need an SS I havent had one on in 2 years. I also have no track bars and I dont run a sway bar. It is most likely your tires being out of balance.
Ask me how I know...
Siva283 is offline
post #20 of 35 Old 04-12-2013, 01:52 PM
Zeus82more
When I first got my 99 tj it had a DW when I hit bumps at higher speeds. I thought it was the tires and balance. Got new tires and that helped. But the DW came back. I noticed the stirring shock was leaking. After replacing that the DW was gone. So if the shock has any oil leaking out of it it is not cushioning any blows ie causing it to wobble. Let me know wat it looks like
Zeus82more is offline
post #21 of 35 Old 04-12-2013, 01:55 PM
Siva283
You have a Coil sprung TJ he has a leaf sprung YJ. Big Big difference there. Also changing the Steering Stabilizer did not fix your death wobble. It covered it up. It will come back when it destroys your SS again.
Siva283 is offline
post #22 of 35 Old 04-12-2013, 02:27 PM
Zeus82more
True didn't think about that. I was just trying to help. And I replaced my ss almost two years ago and just drove from fl to Cali with still no issues. Something has to be workin.
post #23 of 35 Old 04-12-2013, 02:39 PM
Jax89Jeeper
Just like shocks dampen the bumps in the road.... because your suspension is actually messed up and the shocks just mask it. I know what worked to fix mine... I thought I could leave it out, based on what I had read in various forums, and be great with all new components. So I tried it and found it would oscillate quite a bit.
In my rebuild I replaced the entire steering linkage, ball joints, etc. and had the alignment checked, tires ballanced, and had an oscillation when I first got it out on the road without the SS. I put in the SS and the problem went away. If you say it masks it, then I agree in the sense that masking it equates to stopping the DW oscillation from starting. The SS is a designed part of the system, which was engineered as a whole working unit. Remove a piece and it may work for some, but not for others depending on cumulative in/out tolerences of the system.
-I am not trying to argue, we are all trying to help accomplish the same goal to help the OP
post #24 of 35 Old 04-12-2013, 02:43 PM
Ripper3494
im willing to bet its tierod or drag link ends.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #25 of 35 Old 04-12-2013, 02:44 PM
Sparrows
Two more options I haven't seen mentioned here yet;
1. Get your tires balanced. I got mad DW one time, in the same speed range you mentioned, on my TJ when my tires got really out of balance. They were getting pretty bald and I had somehow lost a balancing weight. Getting them balanced fixed it.
2. Jack up your front end a few inches (just enough to get your tires off the ground) and grab the tire at 12 o'clock and 6 o'clock and give it a good shake. Really work it. It shouldn't move at all. If it does, you have blown up ball joints which can also cause DW (another personal experience I had.)
I'm far less knowledgeable than most of the pro's on here, but I never see anyone suggest the above in DW threads, and in both my DW cases, those were the problems so at least I can speak from experience.
Cheers
June '13 YJOTM
Sparrows is offline
post #26 of 35 Old 04-12-2013, 02:46 PM
Ripper3494
if you'd really like to get technical about the purpose of a shock in your suspension vs a steering stabilizer we can but that would mean an extreme thread derail. shocks and steering stabilizers are not built the same nor do they serve the same purpose. they may look the same on the outside, but inside they are very different.
build thread:
RC vs BDS
post #27 of 35 Old 04-12-2013, 02:48 PM
Ripper3494
Cheers
aw lol
build thread:
RC vs BDS
post #28 of 35 Old 04-12-2013, 02:50 PM
Zeus82more
Ya vary true. Sorry man. Hope mine holds till I rebuild it. Btw I used to live in jax before I moved out here. Small world.
post #29 of 35 Old 04-12-2013, 03:03 PM
Jax89Jeeper
I know the many differences.... You didn't get my point. -done with this.... Good luck to the OP.
post #30 of 35 Old 04-12-2013, 05:07 PM
Siva283
Exactly Ripper your one smart cookie. ..
Sent from my Galaxy S3 using JeepForum
Siva283 is offline
