Death wobble, sway bar??? - JeepForum.com
post #1 of 35 Old 04-12-2013, 09:56 AM Thread Starter
Matthew93
hello, just trying to find out the steps here, I get the death wobble around 56 to like 63 it can get pretty violent. I have seen alot about checking the sway bar so i took 2 pics, pretty sure its the end of the sway bar... looks like it should be interconnected with 2 bolts and its pretty much out of both. let me know if 1 that's what it could be and 2 that this is even the sway bar connect ! LOL stock 95 jeep, my first one, so she's definitely making me learn some things, thanks for any and all help here's the pics!!
Matthew93 is offline
post #2 of 35 Old 04-12-2013, 09:58 AM
Kodiak17
Shouldn't be your swaybar. Do a dry steering test.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #3 of 35 Old 04-12-2013, 09:58 AM
Jeepsr4me
Sway bar is NOT causing you DW.. Can take those off completely and not have any issues.
More likely is tie rods, or hub bearings or bad tires or alignment
Jeepsr4me is online now
post #4 of 35 Old 04-12-2013, 10:00 AM Thread Starter
Matthew93
what do you mean by a dry steering test? so the above picture, pretty much irrelevant to the problem?
post #5 of 35 Old 04-12-2013, 10:02 AM
Agent620
Yes, Go look at the front end while someone is turning the wheels back and forth and look for loose steering components. I.E a dry steering test.
Agent620 is offline
post #6 of 35 Old 04-12-2013, 10:04 AM Thread Starter
Matthew93
okay will try that, thank you!
post #7 of 35 Old 04-12-2013, 10:07 AM
Jeepsr4me
Can even wedge it up against a curb to really get some movement when you testing.
Could even be brakes that are dragging. Heat builds up as speed goes up.. closes the piston
post #8 of 35 Old 04-12-2013, 10:10 AM
Dirttracker18
The steering boxes are none for getting loose. Some adjustment can be made (see the FAQ section for tech tips)
As has been noted, get someone to slowly move the steering wheel back and forth about a 1/4 turn and look at each connection point in your steering. Both parts should move together.
That or take it to a shop. Most National chain shops will do free estimates and that will let you know right away what is wrong under there.
Dirttracker18 is offline
post #9 of 35 Old 04-12-2013, 10:12 AM Thread Starter
Matthew93
alright sounds great ill give all that a shot and look into the brakes and steering box, thanks everyone
post #10 of 35 Old 04-12-2013, 10:12 AM
Imped
Imped's Avatar
Your sway bar has nothing to do with keeping your axle constrained.
OlllllllO
IndyORV
Imped is offline
post #11 of 35 Old 04-12-2013, 10:25 AM
Jax89Jeeper
Steering stab failure can lead to DW too.
Jax89Jeeper is offline
post #12 of 35 Old 04-12-2013, 10:53 AM
Kodiak17
How so?
Kodiak17 is offline
post #13 of 35 Old 04-12-2013, 11:11 AM
squishy
Nope.
squishy is offline
post #14 of 35 Old 04-12-2013, 11:31 AM
Jax89Jeeper
YEP! the steering stab dampenens the osscillation of steering components. I have all new steering components, bearings, etc. and a fresh alignment. I left off the steering stab, this lead to DW induced by bumps on the road at 30-40mph. Put the new stab in place and the DW is 100% cured. I know this from direct personal experience in the past few weeks on my rebuild. A degree in physics and engineering don't hurt either.... I don't speak unless I know what I am talking about....
post #15 of 35 Old 04-12-2013, 11:35 AM
Kodiak17
YEP! the steering stab dampenens the osscillation of steering components. I have all new steering components, bearings, etc. and a fresh alignment. I left off the steering stab, this lead to DW induced by bumps on the road at 30-40mph. Put the new stab in place and the DW is 100% cured. I know this from direct personal experience in the past few weeks on my rebuild. I don't speak unless I know what I am talking about....
The SS is a dampener... meaning its hiding the DW. So its still there you just can't feel it.
Kodiak17 is offline
