Death Wobble - JeepForum.com
post #1 of 11 Old 10-06-2012, 10:46 PM Thread Starter
Rabbitsh
Death Wobble
I been crashed by side, and after that my jeep vibrates a lot when i go for 38 mph+-, a friend told me it is called Death wobble. I was wondering if someone know how can i fix it in my home? or how expensive is to fix it if i cant do it, im not very experienced in mechanics but if someone explain me (better if have pics) i can do it by myself. Thanks
Rabbitsh is offline
post #2 of 11 Old 10-06-2012, 11:10 PM
sdotcarter
99% of Jeep yjs (or Jeeps with leaf springs not coils) DONT get death wobble, and if the do, its from the front end. Because I like to keep posts relevant, check these items:
1. Have you been off roading? Check for a bent rim.
2.check your tire pressure. Smaller tires (stock) = larger psi. In my 32's I run 25 front, 27 back.
3. Bent axle.
4. Ball joints or bearings. (Park truck, push and pull on all the bars that are on the front end.(these include but are not limited to: tie rod ends, and drag link)
5. If wobble during braking, then probably warped rotors.
Edit, also check your lug nuts.
But back to your situation, you got t-boned. Make sure your frames straight and have it checked out at a shop.
Good luck!
sdotcarter is offline
post #3 of 11 Old 10-07-2012, 12:53 AM
Michaelgoesrawr
Crashed by your side? What?
Post pictures of your steering set up, skid plate and rear axle and drive shaft. Chances are something is botched there.
Edit:^^ He did a better job. Haha.
Michaelgoesrawr is offline
post #4 of 11 Old 10-07-2012, 01:23 AM
lestes94
Miss-alignment in the front or possibly losing a tire weight could spark it.
'94 YJ: 4.0L HO fi, 5-speed AX-15, Daystar 1.25" shackles, 17" JK wheels, lined tub, custom paint, Bestop Supertop, etc..
'88 YJ: 4.2L carb, 5-speed, stock everything. Banana-ish yellow. hard top. 26,XXX original miles.
lestes94 is offline
post #5 of 11 Old 10-07-2012, 02:19 AM
BowHunter70
I used to get "death wobble" at or around 55 to 65mph. For my particular situation, it was fixed by having my front and rear drive shaft balanced after correcting poor pinion angle on the rear. now, no issues up to 70mph. I do not exceed 70 seeing as i do not have a track or sway bar
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
Herm Albright
(1876 - 1944)
My Jeep: 1992 Wrangler YJ, OME, 2"Body, SYE, ARB Front W/Smittybilt 8000, 33x12.50x15 BFG AT/TA/KO laced onto some Black Steelies. D44 /4.56 ChroMo shafts & ARB locked. D30 / 4.56 ChroMo 1pc ChroMo shafts & ARB locked. Next up is the, B&M Shifter, and whatever else I can think of...
BowHunter70 is offline
post #6 of 11 Old 10-07-2012, 11:22 AM
navman
Death wobble is actually 2 problems at the same time.
1 something is out of balance
2 components in the steering or the suspension are loose/worn allowing the tires to wobble back and forth regardless of how tight you hold the wheel.
95 YJ 5.0 linked etc
navman is offline
post #7 of 11 Old 10-07-2012, 11:41 AM
sdotcarter
Dude got tboned. If it was fine before then its probably a bent frame
post #8 of 11 Old 10-07-2012, 10:15 PM
ox-yj
Do you get death wobble when u hit a bump? Check your pit man arm the nut might be loose and as stated check you tie rod ends for wear. How old are your tires? Try rotating them.
ox-yj is offline
post #9 of 11 Old 10-08-2012, 09:27 PM Thread Starter
Rabbitsh
I found some loose things on the swaybar so i might change the bolt because with the vibration the hole became bigger. Ill try tighting that. Im about change the front tires so ill have the 4 new. then i alineate and balance them. If it doesnt fix it, ill have to call a mechanic.
Rabbitsh is offline
post #10 of 11 Old 05-13-2013, 10:35 PM Thread Starter
Rabbitsh
Thanks to everyone that posted the possibly fixes for my jeep.
I know this is an old post but i solved it 2 months ago, when i needed go highway.
The problem was the steering stabilizer shock. Just that. Also replaced the front tires for new ones but that was after the shock. I invested a some cash to fix all the things that sounded on my jeep and actually rides great. here is a picture of the new image of the Rab*****. I hope you like it.
Rabbitsh is offline
post #11 of 11 Old 05-14-2013, 11:29 AM
remmons
A new steering dampener only masks the problem, it does not fix it. (Ask me how I know). Hopefully your issue was only a bent rim or loose steering components.
Your rig looks cool.
Robert.
remmons is offline
