Dead Heep this morning - JeepForum.com
post #1 of 18 Old 03-13-2014, 07:18 AM Thread Starter
brzehentmaier
brzehentmaier's Avatar
Went out this morning and the jeep wouldn't start. All electrics work (lights,radio thats all it has) Proper warning lights on dash light up, turn the key and nothing. No click just nothing. If it was the starter it would at least click but not engage, correct? Should I be looking at the starter solinoid instead of the starter first? If I jump the solinoid and it starts then I can rule out the starter. Then it would have to be the solinoid or ignition switch. I am hoping solinoid but I don't know. I went to the store last night and it did the same thing but I turned the key off and back on and it started.
What a way to start the day.
Bernie
1995 Rio Grande
31 x 10.5 x 15 Tires
1.5 Body Lift - Skyjacker Hydros
2.5 - Auto - Crager "D" Slots
A Work In Progress
2004 Liberty Columbia Pkg.
A new begining
brzehentmaier is offline
post #2 of 18 Old 03-13-2014, 08:31 AM
Louie4
Start with the basics. Check your battery connections. If that checks out have the battery tested, then the starter, etc.
A loose connection can cause a lot of weird problems.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 18 Old 03-13-2014, 08:35 AM Thread Starter
brzehentmaier
Thanks Lou, I'll check the basics.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #4 of 18 Old 03-13-2014, 08:36 AM
jaycal3
Check the ground from the battery to the block. I had the same symptoms a while back and that's what it was...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #5 of 18 Old 03-13-2014, 09:13 AM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Check for loose battery connections, then give the starter a decent hit with a hammer. Then see if it starts. If it does you have hit the problem on the head!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #6 of 18 Old 03-13-2014, 11:09 AM Thread Starter
brzehentmaier
I park on the busy street which is a salt haven here in Chicago, good possiblity salt got in there.
Gonna feel like old times, Havn't smacked a starter with a hammer in years. Ahhh memories.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #7 of 18 Old 03-13-2014, 01:21 PM
XJ93
DO NOT WHACK THAT STARTER! That is the worst thing you can do, if it doesn't work and it wasn't your issue you now have weakened the magnets inside the starter. More than likely it is either a loose connection or the ignition switch is loose/worn. After you check your battery connections crawl under the dash and look for the switch, it will be on top of the column with a rod going into the front of it. Many times I have seen where the screws come loose and the switch slides back just a little bit and you get power but no crank. Sometimes the act of turning the cylinder back pulls the switch just far enough forward for it engage the next time you crank, and a lot of people also seem to think that turning the cylinder harder and farther works (in a way it does because it forces the rod ever so slightly that much more forward again aiding in engagement).
XJ93 is offline
post #8 of 18 Old 03-13-2014, 01:27 PM Thread Starter
brzehentmaier
That is exactly what I did when it happened last night.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #9 of 18 Old 03-13-2014, 03:20 PM
XJ93
I know this whole scenario very well..I had an 89 Firebird that would do the same thing. I spent a week trying to trace it down. It would randomly shut off, turn the key back then forward and it would start right back up. Finally someone pointed out the switch itself and sure enough the screws had come loose allowing it to move back and forth.
XJ93 is offline
post #10 of 18 Old 03-13-2014, 07:40 PM Thread Starter
brzehentmaier
Ok I checked the ignition switch and all is good. Just barely tapped and I mean tapped ever so lightly the starter and she cranked right over and fired up. BINGO!!!!! I am not even going to mess with it. I'll replace the starter over the weekend. Thanks again for all the help. Now which auto part chain has the best quality starter. I went through 3 bad alternators from Lee Auto before I got a good one. I had a pep boys starter that I had to change every 6 months. Most of the auto stores around here are like fast food joints. Poor quality to fill a void for awhile. All the small good parts stores have closed down. Anyone have a preference and which fast food parts store has the best quality? Oriely, Advance auto, Autozone, Pep boys or Lee auto. I have already had bad luck with Pep Boys and Lee. Any thoughts?
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #11 of 18 Old 03-13-2014, 07:49 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Bernie
If the starter does not a 'dead spot' in it then this starter would not turn this engine over again, period. Assuming that everything is tight/clean I think it is the temp sensor in the t-stat housing.
Easy way to find this out. Run it again until it is fully warmed up just like you did earlier. Shut it off and wait ten minutes. Hit the key and see if it doesn't start again. Pull the temp sensor wire then see if it does start. If it does it is the temp sensor. And it didn't cost you anything but time to figure out!
post #12 of 18 Old 03-13-2014, 08:07 PM Thread Starter
brzehentmaier
Man that's great info. . Tomorrow night I'll give it a try. The temp. sensor i'm sure is a lot cheaper than a starter. It's been a couple of years since I bought one. I'm sure they are pricey now. Thanks again for the info., I would have never checked that i'm sure of that.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
post #13 of 18 Old 03-13-2014, 08:12 PM
langwilliams
if you do replace the starter, I always have the best luck with NAPA stuff, anytime I replace something that's a pain in the a** to get to I go to napa
langwilliams is offline
post #14 of 18 Old 03-13-2014, 08:14 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Alternators, starters, water pumps...buy new it is cheaper in the long run.
post #15 of 18 Old 03-13-2014, 08:14 PM Thread Starter
brzehentmaier
I'll have to google a location here in chi-town.
Bernie
1995 Rio Grande
A Work In Progress
A new begining
