DC yoke to standard ujoint yoke - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > DC yoke to standard ujoint yoke
CCOR is Hiring! Athens, GA!ZONE 4.25" combo lift for TJ available at Rockridge4wBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread Yesterday, 12:32 AM   #1
DesertLight
I've had a thought for a while about why I couldnt get my front driveshaft into my 92 yj mainly because there were just holes and were deep enough a u bolt couldnt get through there. I bought a np231 from a guy, however I now realize the front yoke is for a double cardan style joint. I dont have the space nor funds to put a dc joint in there and well a new driveline is out of my budget.
So my question is this, can I take that front yoke off the tcase and replace it with a standard u joint yoke without problems and if so what do I need to buy
(as in splines and length)?
I'm hoping the angle isnt going to be to much for a standard u joint set up to handle. I just put a 2.5 inch lift on it.
DesertLight is offline   Reply With Quote Quick reply to this message
double cardan , drive shaft , np231 , u joint , yoke
