dashboard gauges not working - JeepForum.com
post #1 of 4 Old 08-07-2011, 10:13 PM Thread Starter
shu2kill
hey. i just came back from a semi-light wheeling trip. i broke 2 shock absorber bases, but i will weld them back tomorrow.
the problem is that, my gauges arent working. i dont have the rpm meter, speed meter, nor any of the other gauges. the fuel gauge went all the way right, to the FULL position, and the battery, temp, and oil, went to the left.... i didnt notice when it happened, so i dont know what could be wrong... im thinking a broken/loose cable, but, where should i start looking?? i dont have any gauge right now....
my jeep is a 92 YJ, 6 cil, if that makes a difference...
thanx!!
shu2kill is offline
post #2 of 4 Old 08-08-2011, 10:05 AM Thread Starter
shu2kill
anyone??
shu2kill is offline
post #3 of 4 Old 02-15-2014, 11:08 PM
matrix311
Did you figure this problem out? My YJ started doing this same thing today. Please post up the fix if you figured it out.
Eric - *'92 White YJ, 4.5" custom Deaver springs, 35" MTRs, Tera-Low 4:1, CAI, Rear 8.8, Chromo D30, 4.88s, locked front/rear, full cage and front/rear tube fenders.
*'08 Silver Rubicon JKU 2.5" lift, 5.13's and 35's
matrix311 is offline
post #4 of 4 Old 02-17-2014, 01:50 PM Thread Starter
shu2kill
if i remember correctly it was a fuse of the fusebox under the steering wheel...
shu2kill is offline
Dashboard and lights stopped working, where do i start looking? myoung YJ Wrangler Technical Forum 12 12-26-2009 08:41 AM
Replacing dashboard gauges Mikey1234 YJ Wrangler Technical Forum 5 12-09-2009 02:06 PM
Dashboard cluster quit working..... BringThaPain TJ Wrangler Technical Forum 14 08-12-2008 03:47 PM
Dashboard Gauges kejhart TJ Wrangler Technical Forum 7 08-30-2007 03:17 PM
dashboard gauges help ricky84 TJ Wrangler Technical Forum 8 06-15-2004 05:32 PM
