dash Wiring HELP!!!! - JeepForum.com
post #1 of 14 Old 08-28-2011, 12:17 PM Thread Starter
Asia517
YJ Wrangler
I just replaced the entire wiring harness in my 88 yj 4.2l, im putting the dash back together and I cant figure out what some wires go to. check it out here
http://www.wranglerforum.com/f8/dash...ml#post1516535
any help is greatly appreciated.
Asia517 is offline
post #2 of 14 Old 08-29-2011, 07:05 AM Thread Starter
Asia517
YJ Wrangler
Anyone?
Asia517 is offline
post #3 of 14 Old 08-29-2011, 07:43 AM
Que89YJ
Que89YJ is offline
post #4 of 14 Old 08-29-2011, 09:33 AM
bharris68
Daily Driver
Welcome to the Forums!
Let's ask a couple of pretty straightforward questions:
1) what caused you to remove the old harness?
2) From what source - donor vehicle or Painless Products - did you obtain your wiring harness?
2.5) If From a Donor Vehicle - what year, make, model, engine and transmission type?
Thanks!
bharris68 is offline
post #5 of 14 Old 08-29-2011, 09:35 AM Thread Starter
Asia517
YJ Wrangler
Old harness burnt up, new one is from a donor vehicle however I'm not sure exactly what yr make model, I know it was a 4.2l and thats about it.
Asia517 is offline
post #6 of 14 Old 08-29-2011, 09:47 AM
Que89YJ
Follow the post and look at the wiring color code. It should point you to what you are looking for.
Que89YJ is offline
post #7 of 14 Old 08-29-2011, 11:26 AM
bharris68
Daily Driver
Thanks Asia - if you fill out your profile that will help us a great deal - here are some things that may be different from one Jeep to another and therefore may effect or impact your harness. i.e. do YOU have a 4.2 in yours as well?
A/C
Fog Lights
Engine Type
Automatic or Manual Transmission
etc.
Not huge items - but I'm asking these questions because without knowing - it's hard to know specifically what the connections may be for exactly.
Thanks!
Brett.
post #8 of 14 Old 08-29-2011, 12:04 PM Thread Starter
Asia517
YJ Wrangler
It is a 88 yj 4.2L manual trans, no accessories, the jeep the harness came from mary have had accessories, im not sure
Asia517 is offline
post #9 of 14 Old 08-29-2011, 12:21 PM
Que89YJ
I am in the middle of a move so it's impossible for me to look it up. The wire codes should help figure it out. I am try to think what it could be like the chime module, mainenance module, fogs, rear wipe(hard top) and door switches. Look at the schematics I posted. They should help.
Que89YJ is offline
post #10 of 14 Old 08-30-2011, 01:57 PM
Flajeeper1
1987 YJ Wrangler
I can identify several of your connectors. However if you could post your pictures on JF and number each pic we'll be glad to help. The wiring diagram is also a good place to work from. Post those pics.
Flajeeper1 is offline
post #11 of 14 Old 08-30-2011, 06:04 PM Thread Starter
Asia517
YJ Wrangler
I didnt put the pics here because it wont let me do attachments. how do I post them?
Asia517 is offline
post #12 of 14 Old 08-31-2011, 09:40 AM
yabo71
Pictures
Asia517, Thought I would post the pictures for ya... I have a couple of the same ones loose on my 89 2.5 YJ
yabo71 is offline
post #13 of 14 Old 08-31-2011, 10:56 AM
bdheaton
Junior Member
3rd pic looks like the connector the the AC/heater blower fan switch on the left of the heater control panel. Bottom pic is the light sockets for the heater control panel and something else - probably an ashtray light?
bdheaton is offline
post #14 of 14 Old 09-17-2011, 09:10 AM
MaddBones702
1st pic is for rear defogger
4th for fog lights
last picture is the dash indicator lights that go next to the fog light and defogger switches. to the right of the steering column
MaddBones702 is offline
Dash wiring jenniferjeep YJ Wrangler Technical Forum 1 07-02-2010 09:28 AM
Dash wiring.... walt0023 TJ Wrangler Technical Forum 5 10-18-2009 02:52 PM
Under dash wiring... Jeepinjon YJ Wrangler Technical Forum 0 04-25-2007 02:02 PM
under the dash wiring brettp YJ Wrangler Technical Forum 1 08-16-2005 02:48 PM
under dash wiring brettp YJ Wrangler Technical Forum 1 08-09-2005 06:50 PM
