dash speaker help please - JeepForum.com
post #1 of 11 Old 08-25-2007, 10:39 PM Thread Starter
echoduckjr.
i have a pair of pioneer dash speakers 4x6 i ordered from crutchfield for my 1994 yj.. after an hour or so of throwing things i finally got the passenger side installed. now im on the driver side and i've been messing with it for an hour and cant seem to get the top two screws out of the old speaker. crutchfield's instructions dont help much so i was asking for some help, if anyonbe has done it before, or knows how, can you let me in on how to do it before i just take it to a mechanic and have him install the driver side speaker??
thanks in advance...
echoduckjr. is offline
post #2 of 11 Old 08-25-2007, 11:09 PM
coonass
patience grasshopper..small hands help the most!!!
They are a PITA, but grab a beer and head back out to the garage and try again. mine took a while as well.
coonass is offline
post #3 of 11 Old 08-25-2007, 11:11 PM
Mr YJ
Try searching, this has been discussed so many times.
Originally Posted by Brian2o0o
If I can get my hands on my g/f's kayak I will try it...
92 YJ 2.5L 5sp manual trans. 4" lift with 33 X 12.50 Mickey Thompson Baja claws.
Rockhard cage, and SBC swap. Work in Progress
Mr YJ is offline
post #4 of 11 Old 08-25-2007, 11:12 PM
SWAMPED
Junior Member
did you take the dash pieces around the speed-o and the steering column off? that gives you a lot of extra room to move. and when you put your new ones in uy some wing nuts cause thenyou dont have to get a wrench i their ;-). thats what i did. and yes it really sux doing this job but when you are going 60 mph you will be very happy because you can actually hear your radio :-)!
SWAMPED is offline
post #5 of 11 Old 08-25-2007, 11:17 PM
Canuck_Guy
drop the windshield... remove the bolts holding the dash in place and this is an easy job 1 hour tops
Canuck_Guy is offline
post #6 of 11 Old 08-25-2007, 11:33 PM
shinigami
i feel lucky, i got both speakers put in in just 30 min, 20 min to the drivers side.
yes small hands help, (Im 18 and Asian)
i just held the right size socket and hand tightend it.
Id do it for you if you were close.
may the force be with you
Originally Posted by jmathis3 View Post
lots of hair pulling, tool throwing, beer drinking, swearing, and eventualy it will start. haha good luck.
I LOL'd
I.Y.A.A.Y.A.S.
shinigami is offline
post #7 of 11 Old 08-26-2007, 01:34 AM
goatboy
Yeah, this subject gets discussed here in the Tech Forum at least twice a week! It's been beat to death, maybe it's time to beat it to death in the correct forum!! LOL
However, I'll say it again...I didn't even mess with these dern thangs...regardless of what quality speaker you put in there, they will never work as well as speakers mounted in an enclosure, such as a door, the trunk, what have you...so, I simply trotted on down to Best Buy, bought a coupla 4X9 speaker boxes, slapped a coupla decent quality drivers in there, and ... voila! Excellent sound...mounted them on the rear wheel tubs... if ya wanted to get fancy, Tuffy makes a real nice speaker enclosure/tool box setup... I lust after them, however, there are some more practical thangs I am lusting after currently...
goatboy is offline
post #8 of 11 Old 08-26-2007, 05:24 AM
Jeep25
I did mine by using whatever socket fit the screws and was able to turn it loose by hand. Otherwise, a small socket screwdriver should fit in there to loosen them.
Jeep25 is online now
post #9 of 11 Old 08-26-2007, 01:08 PM
pasinbuy
I put pioneer in mine a short time ago. Do you also have a little cone speaker in the front? If so pushout your speaker grill, mine hit it and made a tinny sound.
On the one you already installed take some wire and hook one end. Then carefully place into the grill and pull it out. For the other do it b4 installing the speaker, much easier. The bad sound from touvhing the grill made me think the speaker was bad.
pasinbuy is offline
post #10 of 11 Old 08-27-2007, 09:49 AM
Exparrot
Exparrot's Avatar
Easiest way to do it without dropping the windshield is to remove the e-brake assembly. Two bolts through the firewall and one under the dash and it will free up quite a bit of room. Otherwise, the suggestions made previously in this thread are spot on. Small hands and a socket was how I did it.
Prepare for much knuckle rash though... :
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
post #11 of 11 Old 08-27-2007, 12:02 PM
Slickdaddydax
1987 YJ Wrangler
when i did it i dropped the windshield and took the dash off. still was not alot of room but it helped. they are a pain in the *** but def worth it. i also have the 6x9s on the wheel wells by the roll bar but with the wind blowing with no top or doors you cant hear them. between the dash speakers and the 2 10" subs behind the rear seat no matter how fast you go the music comes through clear.
87' yj 3.5 blackdiamond lift 33 12.50 truxus mud terrains
I6 bored out 30 over, weber 38/38 carb
hooker headers with true dual exhaust.
Slickdaddydax is offline
YJ Dash speaker replacement ROADDOG516 YJ Wrangler Technical Forum 32 07-15-2017 04:57 AM
Dash speaker wires. which is - and which is +? AlTheKillerr TJ Wrangler Technical Forum 2 10-28-2009 10:57 PM
YJ Dash Speaker upgrade? yjrush YJ Wrangler Technical Forum 19 04-10-2007 11:08 PM
Dash Speaker Recommendations? labsters TJ Wrangler Technical Forum 17 04-11-2006 09:00 AM
Dash speaker brackets ozjeep TJ Wrangler Technical Forum 7 02-22-2006 05:27 PM
