Dash lights not working dont know what else to do - JeepForum.com
post #1 of 16 Old 10-20-2014, 07:34 AM Thread Starter
bck4more
1987 YJ Wrangler
So my jeep had sat outside uncovered in the weather for over a year before i finally got around to rebuild it now im down to the small stuff. The jeep runs great ive drove it out and about a few times dont my dash lights wont work but the gauges are working. Ive read where people say its the dimmer switch and you can bypass it so Ive bypassed it nothing decided to take dimmer switch apart and clean it still nothing. Ive checked the fuses im just lost at what else it could be i dont see any wires that arent left not hooked up or anything that looks strange.
1987 4.2 automatic, 33" Pro Comp, 2100MC, nuttered, SOA, SYE,TW driveshaft
bck4more is offline
post #2 of 16 Old 10-20-2014, 09:07 AM
Berniebikes
more than likely it is one of your tail lights gone bad with a bad ground. I know it sounds funny, but the yjs were built with that as a warning that your tail lights were not working. Have someone check your lights and report back.
Edit: It might also be your light switch, but doubtful. They are pretty heavy duty and don't fail that much. Cheap to replace though.
Berniebikes is online now
post #3 of 16 Old 10-20-2014, 09:33 AM Thread Starter
bck4more
1987 YJ Wrangler
Tail lights are working I installed led flush mount although I have no reverse but that's a different story
bck4more is offline
post #4 of 16 Old 10-20-2014, 11:30 AM
Old4X
1990 CJ7
Pull the gauge assembly out and clean the bulb socket contacts on the PC membrane. While you have it out, stick all new bulbs in it.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 16 Old 10-20-2014, 02:32 PM Thread Starter
bck4more
1987 YJ Wrangler
Already have cleaned the contacts ive checked some of the bulbs and none seem to be blown.
bck4more is offline
post #6 of 16 Old 10-21-2014, 03:15 AM
Gausswave
"The back light circuit chase".....
According to the schematic here's how it should work.
This is probably on the engine side of the fire wall. Green fuse able link hot at all times feeds a red wire.
I'm guessing a bit here but I'd imagine the red wire goes through the fire wall block to get into the cabin/dash area.
Red wire is split in to 2 branches.
One side feeds the headlight switch directly.
The other side feeds fuse #8 in the fuse block. It's a 20A fuse. It comes out of the fuse block red/black into the headlight switch.
>>>If you have running lights and head lights, marker lights and brake lights you can probably eliminate that much of the circuit.<<<<<
Out of the head light switch is a blue wire. It feeds the rheostat that feeds the dash lights. ( as well as most of the parking, signal, interior and brake lights )
Out of the rheostat switch ( the dimmer control ) there is a pink/orange wire the goes back to the fuse block that feeds fuse #10 5A lower left hand side of the block.
It comes out of the block as an orange/black wire to the gages ( and the rest of the dash cluster, heating and meters).
The Meter board uses a black wire for ground.
Do you have lights on the heater controls, tac or speedo? If yes then you can skip the fuse check.
Check fuses 8 and 10. If they are good then you need a volt meter or light probe ( looks like an ice pick with a bulb in it) to see where in the path you've lost continuity.
If you have good fuses then you'll want to see if you have power at the meter board. With the lights on check to see if you have voltage on the orange /black wire going to the back of the meter board.
If you have voltage there then you may have a bad meter circuit board. They can be fixed but you need to find the brake in the trace.
If you don't have voltage there you'll need to work your way back through the circuit till you find the brake or faulty part.
Gausswave is offline
post #7 of 16 Old 10-21-2014, 03:36 AM
JMickey
I'll also add, check for grounds. Checking fuses and power wires are good, but don't neglect checking grounds.
JMickey is offline
post #8 of 16 Old 10-21-2014, 03:39 AM
jay-h
If no lights including speedo are working than it's either the dimmer or the feed from it. Check the voltage at that point.
Worst case, you can simply tap into the taillight lead and run them at full brightness. No one really needs a dimmer in a Jeep
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #9 of 16 Old 10-21-2014, 03:53 AM
Gausswave
In this case ( and the way I'm having him trouble shoot ) if there was bad ground the meters wouldn't work correctly and that was not a reported symptom. Although there could be a bad ground on the meter circuit board for just the illumination ( but not likely since it's all the lights and none of the meters) it's self but that isn't a general ground fault in the same way most grounding problems are solved on a jeep.
post #10 of 16 Old 10-21-2014, 07:01 AM Thread Starter
bck4more
1987 YJ Wrangler
Thanks for the info guys. Im going to try and check some of it out tonight. Also i do not have any lights on my speedo, rpm nor on the heater controls. The dimmer switch will turn on the floorboard lights though.
bck4more is offline
post #11 of 16 Old 10-21-2014, 10:56 AM
Gausswave
The dimmer switch is 2 parts in one housing. A dimmer for the dash lights and switch for the interior lights. Which makes it a good place to start since you say the fuses are good.
They are actually discrete circuits. The black is a ground, the black /white goes to the interior lamps and should be hot all the time. The switch just provides the path to ground to turn on the lights.
The blue wire provides the power for the dash lights when the headlight s/w is on. The pink/orange feeds the fuse block>dash lights. You can just jumper them to bypass the rheostat to see if it's bad.
post #12 of 16 Old 10-21-2014, 11:40 AM Thread Starter
bck4more
1987 YJ Wrangler
I have already cut the 2 outside wires and wired them together to bypass but still no change then I pull it apart and cleaned it to pretty much looking like new
bck4more is offline
post #13 of 16 Old 10-21-2014, 07:38 PM
Gausswave
Do you have power on the blue wire? Do the head lights work?
post #14 of 16 Old 10-21-2014, 08:36 PM Thread Starter
bck4more
1987 YJ Wrangler
Well i started going through the steps that Gausswave had listed and got to rechecking the fuses again and chose to replace them and the #10 5A lower left hand side of the block didnt show that it was blown but i put in a new in and NOW I HAVE DASH LIGHTS. cant believe thats what it was. Thanks for the help guys
bck4more is offline
post #15 of 16 Old 10-21-2014, 11:12 PM
Gausswave
Well as much as I love an easy fix I'd be worried about the rest of the terminals in the fuse block. Given the open air exposure I'd be concerned about corrosion. Check the fuse to see if it is really blown. They don't usually just blow at random. Do a cursory check of the wires at least to see if you can find an intermittent short some where.
