Dash Lights - JeepForum.com
post #1 of 4 Old 08-15-2011, 08:34 AM Thread Starter
rpenczek
Dash Lights
Last week I lost the lights (both) in my speedo. I pulled the gage cluster on Saturday and installed new bulbs (believing that to be the problem.) Well, they still did not light up. So I took it apart again and did some inspection. It appears that some of the copper lines on the circuit board (I know its not a board, more like plastic sheet with copper lines) coming from the tach side to the speedo side had some green corosion and what looked like a break in the copper. I am assuming this is my problem.
Question, is this common? Also, assuming this is my problem, is the plastic film with the copper lines available anywhere other than a bone yard?
Also, anything else I should consider?
Thanks.
rpenczek is offline
post #2 of 4 Old 08-15-2011, 08:58 AM
tdewit
It's not uncommon for that to happen. Rather then replacing, use a pen eraser to clean the corosion off, and a soldering iron to fix the tracks.
tdewit is offline
post #3 of 4 Old 08-15-2011, 09:20 AM Thread Starter
rpenczek
TY for the tip. I did use the eraser to clean up the corosion (thats what we did as kids on model railroad tracks to clean them up). I didn't know how to fix the broken lines. soldering should do the trick (as long as I don't burn the plastic up).
rpenczek is offline
post #4 of 4 Old 08-15-2011, 11:37 AM
Que89YJ
You can get a conductive paint or a copper trace repair kit that has copper tape. I know someone here just did it but I cant find it.
Watch this video:
Que89YJ is online now
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 06:33 AM
89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights Cajun90YJ YJ Wrangler Technical Forum 9 10-03-2010 06:33 PM
TJ Dash lights, and other interior illum lights not working kells81 TJ Wrangler Technical Forum 2 02-22-2010 10:05 AM
No dash lights, tail lights or parking lamps BlkBird TJ Wrangler Technical Forum 5 01-11-2008 09:03 PM
2000 Wrangler No park Lights or Dash Lights Deb04 TJ Wrangler Technical Forum 2 04-06-2004 11:28 PM
