Dash indicator lights - JeepForum.com
post #1 of 9 Old 11-20-2008, 06:53 PM Thread Starter
Cross
What dash lights should I have? When I turn the key the only lights I see are check engine, shift light(compass), seat belt. I have read others on here talking about a parking brake light which I would like to have. Lately I have been letting the Jeep not wanting to move remind me that the parking brake is on.
Cross is offline
post #2 of 9 Old 11-20-2008, 09:56 PM
jeepmech06791
jeepmech06791's Avatar
the switch for the parking brake has a small "arm" that hangs off of it, it may be broken off, causing your problem. I know thats whats wrong with mine, call up the stealership for the switch.
91 yj, swaped 4.0, ax15, twin stick stak case, one inch daystar bl, SOA, Waggy 44 front, 8.8 rear, 35x12.5 BFG KM2, Allied Rock 8 bead locks, AGR hydro assist, m8000 warn
jeepmech06791 is offline
post #3 of 9 Old 11-20-2008, 09:59 PM
RikRotorhead
Did you check the bulb?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #4 of 9 Old 11-20-2008, 10:05 PM Thread Starter
Cross
Not yet, I am not looking forward to pulling the dash apart, my tach light is also burnt out.
Is the parking brake light the only one missing?
Cross is offline
post #5 of 9 Old 11-21-2008, 10:40 AM
rrisher
1987 YJ Wrangler
Well, most likely is a bulb then seeing if you have others out in the vicinity....
rrisher is offline
post #6 of 9 Old 11-21-2008, 01:09 PM
bestos
pulling dash for light replacement for TACH is cake! just need a phillips head. go for it!
1995 YJ - 33" BFG KM2 - 4.88 w/ Aussie front locker. 2.5" OME. 5/8" shackle. 1" JKS body.
1991 YJ - 4.0 - Stock and banged up and recent purchase
bestos is offline
post #7 of 9 Old 11-21-2008, 01:32 PM Thread Starter
Cross
I have not really looked at it. I am just slowly going through the Jeep fixing a bunch of minor things. Sucks that all the stuff I really want to work on is 3 hours away at my brother in-law's shop.
Cross is offline
post #8 of 9 Old 11-21-2008, 07:27 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
u have all those lights? heck.. i only have the blinker lights and that's it.
Thomas
-1987 YJ
Tompatt is offline
post #9 of 9 Old 11-22-2008, 05:22 PM Thread Starter
Cross
I just got my dash put back together. I now have a parking brake, check engine, brights, turn signals, 4x4, maintenance required, shift, and seatbelt light. I also put the little light above my rear wiper and fog lights switches back so I can now see them at night. The tach now has new bulbs also. the dash piece also had check oil and anti-lock brake windows. I guess my Jeep does not have those features since there is no wiring to the spots the bulbs would go.
My turn signals have some very touchy connections. I had to wiggle the bulbs to get a decent delay on them blinking. The hazards blink great but the turn signals are a little slow but they are blinking. The right at one point only blinked once every thirty seconds. I have heard it is the connections on the circuit board that cause this. As long as they blink I am not going to touch them.
Being a Jeep as I fixed one issue I found others that need attention. The line connecting to the vent controls has broken the plastic post it goes on. I knew my vent never worked quite right but now I know why.
Cross is offline
Dash indicator lights southbound YJ Wrangler Technical Forum 9 01-02-2010 12:04 PM
dash indicator lights-connection problem? whitie_08 YJ Wrangler Technical Forum 4 10-21-2008 09:11 AM
Dash and Indicator lights denalione YJ Wrangler Technical Forum 0 05-17-2008 09:39 AM
4WD Indicator Lights on Dash CTKen TJ Wrangler Technical Forum 12 12-31-2007 03:46 PM
87 dash indicator lights wdhigh YJ Wrangler Technical Forum 7 05-12-2007 08:23 PM
