Dash Conversion Yj to Custom Dash - JeepForum.com
post #1 of 8 Old 01-01-2014, 08:08 PM Thread Starter
wirerat
Looking to see in there are any recent attempts at this ongoing and who if anyone has performed this without incident.
Currently working on a 1992 YJ and will be performing the following tasks and wanted to ask what hangups I would hit.
1.) high beams relocate to dash off wire harness
2.) Indicator lights and hazards to aftermarket switch (steering column clamp or other) - looking for this part else to dash panel multi switch
3.) windshield wiper controls to dash (switch panel)
4.) slim steering column (aftermarket)
5.) all engine indicator lights and cluster panel reworked to HUD lights dash mount
6.) autometer gauges
7.) heater vent relocate - removal of complete plastic dash and tin dash mounting backplate
8.) ignition moved to Dash
9.) custom mounts for CB Radio, Ham Radio, radio
Thusfar the plastic has been removed and working on the steering column plastic and dash plastic around the column.
pulling out all wiring to the column and working it from the connectors off the harness to a remade connector bank (not changing the original wiring harness)
Knowns thusfar
Fuel Gauge tolerances will read 1 ohm empty from sending unit 88 ohms full
Dash customization being considered requires not to reuse old YJ tin pieces and is custom made
Pneu-Con Systems Inc.
P.O Box 5715,
Bend, Oregon 97708
541-382-2552
Contact Mike Garoutte
Gauges O am looking at are from auto meter
Auto Meter
413 W. Elm Street
Sycamore, Illinois 60178
815-895-8141
Any direction or comments / constructive pointers is highly welcome
wirerat is offline
post #2 of 8 Old 01-01-2014, 08:29 PM
NHfireLJ
NHfireLJ's Avatar
You're kidding right? Tons of dashes out there and tons of write ups...
http://www.aqualu.com/jeep-dashes.html
Try the search engine...
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #3 of 8 Old 01-01-2014, 08:47 PM Thread Starter
wirerat
Appreciate the link.. i was not getting much on the searches beyond partial projects
Regards.....
wirerat is offline
post #4 of 8 Old 01-02-2014, 08:16 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Way easier than hacking together something of your own, really fair prices, and full custom, go see Dan Dilner at DoubleDfab.
The top photo is my YJ dash on the bench before install. Dan made the main metal, full custom. Every item is exactly where Dan and I worked out for my needs. I added the full Autometer gauges and other items.
The lower photo is the dash in Dan's garage before boxing to ship.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 8 Old 01-02-2014, 10:10 AM
Rebel442
Ill give another vote for going with double D dash, takes awhile to get but prices are very reasonable.
[IMG][/IMG]
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline
post #6 of 8 Old 01-02-2014, 12:52 PM
superj
that is badass!! /\
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 8 Old 10-18-2015, 10:05 PM
cowboyup0280
JeeperDon I'm working on putting in my custom dash from Dan and was wondering if you or anyone on the forum might have a write up of the wiring
cowboyup0280 is offline
post #8 of 8 Old 10-19-2015, 07:51 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
The wiring completely depends upon what you are using for gauges and how nice you want to make it. I wanted a nice clean setup, so I went to a junk yard and got some random multi-pin connectors, matching female/male pairs. I grouped the wiring into three parts, as you can see below.
Web Admin for
dash , wiring connector , YJ
