#1 | |
Dash cluster bulbs
Hey everyone. Long time reader, first post.
Took the dash out the other day, noticed that I'm missing several bulbs in the center cluster (seatbelt, check engine, etc) and I haven't been able to find any to replace them with. Checked AutoZone & Checker, even looked around on the internet. What I'm needing is the small bulb in addition to the plastic housing which twists into the cluster. Thanks in advance!
#2 |
Those bulbs should be these guys
http://www.partsamerica.com/productdetail.aspx?MfrCode=SYL&MfrPartNumber=74&Pa rtType=312&PTSet=A Can pick them up at any autoparts store. I'm not sure which plastic twisty thing your talking about tho... |
#3 |
Because you're missing the plastic sockets, your best bet is probably to get them from the dealer. I'm not sure what model year you're asking about (please fill out your profile), but there are two different size bulbs in the speedo/tach cluster of my YJ.
Here are the Jeep part #'s and descriptions for the instrument cluster bulbs in the '91 - '93 models: Smaller bulbs (check engine light, seatbelt, etc): Part #5600 1787, LAMP #74 and Socket (Gray) Larger bulbs (gauge illumination): Part #5600 5966, LAMP #194(With Bulb Cap) and Socket If yours isn't a '91 - '93, the dealer should be able to find the correct part #'s for you if they've changed. P.S. Not every lamp socket is used in every YJ, so some of the holes probably don't need bulbs.
[B]His: 1993 XJ Cherokee Sport[/B], 245000 miles (and still going strong), 4x4, 4.0L HO, Auto Trans, BFG A/T's [B]Hers: 1993 YJ Wrangler[/B], 67000 miles, 4x4, 4.0L HO, AX-15, Herculined tub |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
