That dang rear diff just won't stop leaking! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > That dang rear diff just won't stop leaking!
Poison Spyder JK LED Taillight & Wiring Harness KitsPoison Spyder JK Crusher CornersPANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi
Unread 07-19-2013, 11:26 AM   #1
Rproject
Rproject's Avatar
1987 YJ Wrangler
Over the past year I've resealed the rear diff 2x and had a shop do it once. Every time it lasts about 3 months before the cover starts leaking again. The vent line is clean and clear. The cap on the top of the vent line moves and allows air out just fine. I don't get it!!! What do I have to do to keep this thing from dripping on my garage floor?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 11:55 AM   #2
Michaelgoesrawr
Michaelgoesrawr's Avatar
Have you tried a lube locker gasket? I have them on my axles and they haven't leaked a drop
Michaelgoesrawr is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 01:29 PM   #3
Rproject
Rproject's Avatar
1987 YJ Wrangler
I haven't tried lube lockers - yet.
The front diff is fine. The rear diff leaks. This is the only vehicle I've had this problem with. I'm tempted to put a micrometer on the cover to see if it's warped.
1996 White ZJ
Unread 07-19-2013, 01:37 PM   #4
bpounds
bpounds's Avatar
You would check the cover with a straight edge and feeler gauges.
What sealant did you use? Did you clean with alcohol and thoroughly dry the diff and cover before placing the cover? Did you let it cure overnight before refilling?
bpounds is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 02:07 PM   #5
Rproject
Rproject's Avatar
1987 YJ Wrangler
I would use both a micrometer and a straight edge. The micrometer to see if I have varying thicknesses around the cover and a straight to see if it's twisted. As for cleaning, you could have eaten off the axle before I applied new sealant. I've used black, blue and orange RTV. I've followed the directions for application to the letter (assemble immediately or wait until tacky depending on which one was used) and I did them after work so the vehicle sat until at least the next day as this is not my DD.
I'm also considering just upgrading the covers to Solid covers. On my last outing I beat the hell out of both my front and rear covers in a rock field where I got pinned between two dinner table sized "rocks".
1996 White ZJ
Unread 07-19-2013, 03:43 PM   #6
Anticanman
RIP one good jeeper
Anticanman's Avatar
8.8 time.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 04:08 PM   #7
Rproject
Rproject's Avatar
1987 YJ Wrangler
8.8 time.
Funny Nick. Real funny.
1996 White ZJ
Unread 07-19-2013, 04:11 PM   #8
Anticanman
RIP one good jeeper
Anticanman's Avatar
There will be a straw that breaks the camel's back. Maybe not this one, or the next, but it'll come. Mine was a busted lower shock mount.
Unread 07-19-2013, 04:17 PM   #9
Rproject
Rproject's Avatar
1987 YJ Wrangler
It's on the list. Right now I think it's #10 or 11.
1996 White ZJ
Unread 07-19-2013, 06:22 PM   #10
Nickabis
I use a product called "the right stuff" after it is fully cured, you won't need bolts to hold the cover on, ha ha, I don't recommend this.
http://www.permatex.com/products/our...he-right-stuff
Nickabis is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 08:27 PM   #11
UZI4U
I use a standard paper-type gasket and it has yet to leak. I don't use any sealant, etc. on it either...K.I.S.S. I thought about lube lockers, but the paper is cheap enough to be cost effective for lube change intervals.
MCLMM
UZI4U is offline   Reply With Quote Quick reply to this message
Unread 07-19-2013, 09:21 PM   #12
Anticanman
RIP one good jeeper
Anticanman's Avatar
The lube lockers really shine during trail fixes and saving time during the maintenence process. Nobody wants to wait on the trail for rtv to set up.
Unread 07-20-2013, 07:49 AM   #13
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
There will be a straw that breaks the camel's back. Mine was a busted lower shock mount.
Yup, sooner or later... mine was harsh. I did a stupid and bought an ARB for the D35 (I was a noob). The housing did fine with 33's, but for some reason, after three years of trails, the ARB exploded. By then I learned you don't spend for an ARB for a D35 (or anything for a D35 really), and spent the money for an ARB for the 8.8.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 08:36 AM   #14
Louie4
Powah Injanir
Louie4's Avatar
My tipping point was the EZ locker going out and not turning the tires, two time lower shock mount breakage and toasted the outer bearings...then came the 8.8.
As for the leak, try to get a cover from a junkyard and see if it helps. I use to use paper gaskets but found it was easier to keep some RTV in my toolbag.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 07-29-2013, 05:03 AM   #15
jhrebs
1987 YJ Wrangler
I just put on a lube locker rear diff gasket for my 35 and it still leaks!! I am gonna give it one more try. If not then I will use an entire tube of gasket sealer!!!
'87 reg. historic, 2" bds springs, 1" boom shackles, 1" daystar BL, 31" Intereco trxus, Crager soft 8's, steel braided brake extensions, monsta liner
jhrebs is offline   Reply With Quote Quick reply to this message
