Dana 60 vs ford 9 inch - JeepForum.com
post #1 of 31 Old 07-06-2007, 06:11 PM Thread Starter
bayvilleYJ
hey guys , im just finishing up a motor swap and i came across a ford 9 inch. I have a coil spring 44 up front and a ff 60 rear. Now the problems begin. The front is 5 lug and the back is 8 , and i dotn want to swap the outters to 8 lug up front because everything is brand new. Also my 60 is welded and the 9 inch is limited slip , with matching gears to the front 44. I can save myself a lot of money by putting in the 9 inch because i wont have to re-gear , and it comes with really nice rims. My question is , will the 9 inch hold up to my mildly built ford 302 and c-6 combo? If it helps , the 9 inch is out of the same 79 f-150 , and i plan on running either 39.5 tsls or iroks.
bayvilleYJ is offline
post #2 of 31 Old 07-06-2007, 06:12 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
9" all the way
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #3 of 31 Old 07-06-2007, 06:28 PM
jeepervin86
9 inch will handle that like a champ go for it
jeepervin86 is offline
post #4 of 31 Old 07-08-2007, 05:47 AM
Bubba Ray
Go with 9 inch. It will be plenty strong for a 302 and after market is huge.
Bubba Ray is offline
post #5 of 31 Old 07-08-2007, 07:22 AM
TSEJEEPERS
The nine inch is a strong axle but not as strong as a full floater 60. I would keep the 60. Either sell the stuff from the 44 or maybe you can get a spacer/adapter to convert the 44 over to 8 lug. You could have the 60 redrilled to match your 44.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 31 Old 07-08-2007, 09:10 AM
1 ton yj
1 ton yj's Avatar
Go with the 9". It came from the factory behind much heavier vehicles with engines bigger than 302s. It can be built to be as strong as a 60 down the road should you happen to break something. Not to mention they are light and you can shave the housing to have more clearance than your 44 very easily.
1 ton yj is offline
post #7 of 31 Old 07-08-2007, 10:11 AM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
i'd slap some chromoly shafts in the 9" and it would be lighter, stronger, possibly more clearance if you shave it down, sounds like a winner to me
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #8 of 31 Old 07-08-2007, 04:11 PM
hip2Bsquare
I'd keep the 60 unless you plan on selling the 60 and putting the money into the 9"
hip2Bsquare is offline
post #9 of 31 Old 07-08-2007, 05:22 PM
bigstinger
bigstinger's Avatar
609.... be the cool kid
4.0L Ford 8.8 4.56 lsd D30 SOA, 4.56 BFG 35 X 12.50 AT's
Ebay Bushwacker knock-off TJ flares - tuffy security console.
Stainless steel braided brake lines skyjacker pitman arm skyjacker hydros
Buy my unit bearings!
bigstinger is offline
post #10 of 31 Old 07-08-2007, 07:59 PM
mean90yj
mean90yj's Avatar
did you watch that on exteme 4x4 too. i thought that was sweet as hell. honestly how much do you think he spent on putting together everything?
~Enjoy>>>
mean90yj is offline
post #11 of 31 Old 07-08-2007, 08:21 PM
1 ton yj
1 ton yj's Avatar
A lot! That is definetly NOT the cheapest way to do it! I'd like to see them do a junkyard 609 build like most of us would do, but Spidertrax pays more for the show than Billy-sue's junkyard would. All the basic ideas were there though.
I plan on (someday) building a 609 to get rid of my heavy sob ditch-digger 14 bolt. Not any time soon as I am currently too busy wheeling the wee out of it every chance I get.
Here's how I am going to do it.
-junkyard housing shaved, plated and trussed end to end (I dont have leaves)
-Strange low pinion nodular 3rd with 5.13s and Detroit
-WFO housing ends
-Stock GM 60 front spindles and wheel hubs (already sized for 35 spl shafts)
-35 spl Alloy USA shafts.
-Cheapest flanges I can find
A full float 609 with non-bling 80's Chevy truck brakes will weigh in around 300 lbs give or take. Semi float with small 5/6 lug brakes even lighter.
The 3rd will be the most expensive part, but I wrench for a living so I can save some money setting up the 3rd myself as opposed to buying one pre-assembled. Check Ebay, nascar teams sell 9" parts all the time!
1 ton yj is offline
post #12 of 31 Old 07-08-2007, 09:07 PM
bigstinger
bigstinger's Avatar
I get angry watching that show. They do a lot for the scene and all that but sometimes I wonder why I watch a 30 minute infomercial for 3 minutes of tech
That set up would cost more than I am welling to put into a pile of junk that I plan on throwing in the mud and dragging over rocks.
post #13 of 31 Old 07-08-2007, 10:24 PM
jason m
Nothing but the facts
jason m's Avatar
what type of 60 do you have and what did you do to it. do you have the 30 spline axles and the small boar spindles or do you have the 30 spline axles with the big boar spindles to accept the 35 spline axle, if you have the big boar spindles then keep it and upgrade it. remember the 9'' is eather a 28 spline or 31 spline axles so unless you upgrade the 9'' to 35 spline what strength did you gain. your actually going down hill if you install the 9'' your going to a semi float axle. i am not saying they are weak ( the 9'' ) but you allready have the 60 in there and if your end goal is run 39 iroks then i would be worred more about the front 44 handling the 39's than the rear at this point, jason.
jason m is offline
post #14 of 31 Old 07-09-2007, 10:40 AM Thread Starter
bayvilleYJ
Pulled the 60 today and grinded off the old perches on the 9 inch. Should be ready to go. The 44 should be good , its pretty beefed up. Just have to wire the motor now ( yikes). Anyone have an opinion on 39.5 tsl's or the same size iroks? I need to order tires and im torn between the two. I drive around town on the street , and wheel mostly mud and trails. I also drive it on the beach every weekend. I really like the rok's , but i was told they wear fast. I cant really imagine them wearing faster than boggers or tsl's though.
post #15 of 31 Old 07-09-2007, 10:42 AM
mean90yj
mean90yj's Avatar
if your looking for wear and tear then don't order a bias ply, stick w/ a radial swamper or something.
~Enjoy>>>
mean90yj is offline
Ford 9 inch vs dana 44 stokesj19 YJ Wrangler Technical Forum 63 12-22-2016 06:56 AM
Dana 44 / Ford 9 inch Swap into YJ garr79 YJ Wrangler Technical Forum 7 06-07-2010 07:38 AM
dana 44/60 OR dana 44/ford 9" (pics) Michael_94YJ YJ Wrangler Technical Forum 33 06-29-2007 06:44 AM
Ford 9 inch into a TJ? sickboy98tj TJ Wrangler Technical Forum 19 03-20-2006 03:25 PM
Dana 44 Front Ford 9 inch Rear Down&Dirty TJ Wrangler Technical Forum 2 08-30-2004 08:51 AM
