Dana 60 question - JeepForum.com
post #1 of 2 Old 07-24-2001, 08:32 PM Thread Starter
winokko
Dana 60 question
Would any Dana 60 work as a swap for 95 yj, 6cyl 4.0L rear dana 35 and if not what do I need to look for? Probably a stupid question but I don't know diddly! Thanks In-Advance
95, 4.0, 4" sky jacker lift, warn 9500i, tomken rear w/ swing out, 33x12.5 pro comp mud's, 3" body lift, sway disconnects, NO track bars & custom front bumper
winokko is offline
post #2 of 2 Old 07-24-2001, 08:49 PM
Cody_91YJ
Sure you could swap it, but you will need to do a few other things.
You could have Dynatrak custom build you one...but thats some serious $$$$$$$$
When you find one you'll probably have to get them cut down to size if you want them to match the length of the stock axles. Also you'll probably want to shave the bottom of the diff abit so you don't drag it everywhere. I'm not sure about the pinon adapter, it may fit your Driveshaft but I kinda doubt it
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
dana 30 and dana 35 carrier question BigBlackTJ2010 TJ Wrangler Technical Forum 23 02-27-2016 02:12 PM
Dana 35 to Dana 44 swap question? Grim Jeeper TJ Wrangler Technical Forum 38 01-31-2014 04:36 AM
crappy dana 35 question, and 8.8 driveshaft question teejmcd YJ Wrangler Technical Forum 2 12-07-2008 09:50 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 09:20 PM
question about the dana 35 Meabon YJ Wrangler Technical Forum 5 11-09-2003 02:16 PM
