dana 44 wagonner axle swap, vacuum disco - JeepForum.com
post #1 of 3 Old 06-29-2008, 10:45 PM Thread Starter
joe's_yj
joe's_yj's Avatar
Hey, i picked up a front dana 44 out of a wagoneer. it has this weird disconect thing on the diff housing, can someone inform me on what up with this? can i elimate it and do i need a special gear carrier or gears?
not a good picture but you can kinda see it here, this is from google
http://77cj.littlekeylime.com/img/Da...xjco_small.jpg
better, click the fsj drivers side axle link
http://images.google.com/imgres?imgu...3DJ5U%26sa%3DN
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #2 of 3 Old 06-30-2008, 07:43 AM
TSEJEEPERS
Pictures are not working. Try Photo bucket.
I believe all the 44s are the same (exept the Rubicon) as far as the ring and pinion. I am not sure how that disconnect works. Maybe you can make it work with your current set up. I would think you could get a one piece axle to replace it and put a block off plate to get rid of the disconnect. Not sure if you would need another seal though.
Sorry really not much help.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 3 Old 06-30-2008, 02:47 PM
flexncj7
I wouldn't both trying to use that axle- PIA to work with, and they didn't have hubs.
Dana44s are abundant around here, wrecking yards usually want $150-200 for a complete axle (and they remove it)
1985? Jeep CJ-7: 360, 999, D300, LOMAX 4:1, Dana 44s, 4.10's, Aussies front & Detroit rear. S0A, York OBA, YJ tub, 36" IROKs-
1989 YJ Sahara: 258, puko tranny, np231. 2-3" spring and 2" body lift. 33" TSLs- latest project.
flexncj7 is offline
How to: Vacuum Disco Elimination, Axle Tube Sleeve Fix, ubolt eliminator - 56K beware Joe Dillard YJ Wrangler Technical Forum 48 02-17-2016 05:39 AM
Part # for axle seal on vacuum disco to one piece shaft needed willness33 YJ Wrangler Technical Forum 5 11-02-2008 10:25 PM
swapping in HP30 with vacuum disco into tj BK'sTJ TJ Wrangler Technical Forum 1 12-10-2006 06:03 PM
vacuum disco d30 *HELP* grandman97 YJ Wrangler Technical Forum 8 04-19-2006 02:02 PM
Getting rid of the vacuum disco BlackWhyJay YJ Wrangler Technical Forum 8 10-06-2004 03:14 PM
