Dana 44 / Ford 9 inch Swap into YJ - JeepForum.com
post #1 of 8 Old 06-24-2008, 01:57 PM Thread Starter
garr79
Hello,
Specs:
1989 YJ w/ 4.2 w/ 5speed peurgot trans. Not sure about the T-Case
I have searched the forum and found a lot of info on how to swap in a Ford 9 in and Dana 44. However, I have not found anything stating how the drive shafts will mount up to the transfer case.
I would like to use the stock transfer case cause I dont want to spend anymore money on the Jeep for now. Can you use a Ford 9 inch and Dana 44 with the stock transfer case? How will they attach? Are the u-joints the same?
Thanks,
Garrett
1989 Jeep Wrangler. Full Size Chevy Axles, Lincoln Locker Rear, Detroit True-Trac Front 4.10 Gears. 35" Goodyear MT/Rs. SOA on stock springs. TF999 w/ Dana 300. Stock 4.2
garr79 is offline
post #2 of 8 Old 06-24-2008, 02:05 PM
jgillespie
the dana 44 should work fine, as it comes with rubicon models...along with the same t-case i believe. not sure about the ford 9. check the FAQ sticky and YJ stock specks sticky about the 44 just to be safe
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
post #3 of 8 Old 06-24-2008, 02:18 PM
muddy93
1987 FSJ Wagoneer
chances are that you're going to need custom drive shafts anyway(at a very least, you'll need the stock ones modified). it should'nt be much more to just have the correct yokes put on the new shafts.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #4 of 8 Old 06-24-2008, 02:21 PM
MLJeeper
MLJeeper's Avatar
There are a couple different u joints used on the 9". I do know that the yoke off the early bronco 9" and i believe all broncos did use a 1310. Bolts right up and you get rid of the stupid straps
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 8 Old 06-24-2008, 03:24 PM
yjrush
I used the same joints on my D44 conversion, I did have a CV style shaft that had to me shortened a inch due to D44 yoke being longer
1993 YJ 2.5L, 3.5 BDS lift kit, 1" BDS Shackles, 1" BL, 33' Trxsus MT, Tabor 9K, 4.88 gears, Dana44 Spooled, chromoly in D30 with Lockrite, more to come...
2000 Dodge Ram Quad Cab 5.9L (Tow Rig)
yjrush is offline
post #6 of 8 Old 06-07-2010, 04:46 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Originally Posted by garr79 View Post
Hello,
Specs:
Thanks,
Garrett
I have a question........... Are we talking about the same rig that is listed in your sig??????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 8 Old 06-07-2010, 06:35 AM
st2joker
Members 4x4 Gallery | Garrett Rogers
1989 Jeep Wrangler
4.2 w/ Ford MC2100 Carb
TF999 w/ Dana 300 from CJ
Full Size Chevys Locked F/R
35 in Goodyear MTRs
http://www.jolietmudturtles.org/gall..._cw85_ch85.jpg
on this jeep?
88 yj 350 chevy ba10 stock axles, 9" with a locker and a 44 front both with 4.10 gears waiting to go in. new stock springs 1.5 shackles tj flares, 33x12.5x15 coopers 15x8 rims
if you cant have fun, why bother
st2joker is offline
post #8 of 8 Old 06-07-2010, 07:38 AM
MLJeeper
MLJeeper's Avatar
This threads like 2 years old.
MLJeeper is offline
Ford 9 inch vs dana 44 stokesj19 YJ Wrangler Technical Forum 63 12-22-2016 06:56 AM
HP Ford f150 Dana 44 swap questions JwlmanWu YJ Wrangler Technical Forum 7 03-24-2010 08:03 PM
Dana 60 vs ford 9 inch bayvilleYJ YJ Wrangler Technical Forum 30 07-10-2007 10:04 PM
dana 44/60 OR dana 44/ford 9" (pics) Michael_94YJ YJ Wrangler Technical Forum 33 06-29-2007 06:44 AM
Dana 44 Front Ford 9 inch Rear Down&Dirty TJ Wrangler Technical Forum 2 08-30-2004 08:51 AM
