Dana 44 axle specs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Dana 44 axle specs
Hella Items Priced to Move Sale - Work Lamps, Indicator LiSave on Selected Dynomax Exhaust Systems!Rough Country Lift Kits and Parts!
Unread 02-20-2015, 08:54 PM   #1
HB223
Dana 44 axle specs
I had a friend tell me some model dana 44's have an aluminum center (differential) housing. Anyone know what models those are and what year xj's they come off of? And what year xj's have I believe he said steel differential housing?
HB223 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2015, 09:07 PM   #2
Reno72
Reno72's Avatar
That was the D44A, I know it came on the Grand Cherokee but not sure what years.
"Says the guy driving the plastic Barbie Jeep". JLH
I have nothing against a Prius, I just wish the drivers would peddle faster.
Reno72 is online now   Reply With Quote Quick reply to this message
Unread 02-20-2015, 11:31 PM   #3
baritone_mike
Yeah ZJ not XJ.
If you look in the ZJ stock specs or FAQ thread in the ZJ forum it may tell you.
Similarly if you go to the XJ or MJ forum under stock specs FAQ it will tell you what years/options had the D44. Even a very limited number of YJ's got D44 from the factory.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline   Reply With Quote Quick reply to this message
Unread 02-21-2015, 08:09 AM   #4
jserna
1987 YJ Wrangler
WJ's too.
jserna is offline   Reply With Quote Quick reply to this message
