Dana 44/60 Axle Swap - Page 6 - JeepForum.com
post #76 of 86 Old 10-01-2012, 07:55 PM Thread Starter
fuzzy89
would someone tell me how this is stronger than what ive done
http://fullsizebronco.com/forum/showthread.php?t=209130
fuzzy89 is offline
post #77 of 86 Old 10-01-2012, 08:47 PM
G30SFF250
Pssst. Hey, over here.
Hey kid, you're not going to win or convince others that you are right. I would just let this die here.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #78 of 86 Old 10-02-2012, 01:00 AM
fratis
fratis's Avatar
ive done three pitman arms. it has a better chance of holding up because the arm itself is one continuous piece with consistent material. strength is all about consistency. butt welding two objects together with a bunch of filler and obvious seams just naturally raises concern.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #79 of 86 Old 10-02-2012, 06:44 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Its a single wide piece of 3/4" . you meshed metals together.
Poke is offline
post #80 of 86 Old 10-02-2012, 08:48 AM
Hoobah
Originally Posted by USMCBuckWild View Post
Like this. Then apply the plate over the nub to spread load the pull pressure.
What method of welding are you using to attach the D rings?
From what little I know about welding i'm guessing stick welding?
Are there any pros and cons to mig welding opposed to stick welding?
Hoobah is offline
post #81 of 86 Old 10-02-2012, 10:43 AM
Michaelgoesrawr
Michaelgoesrawr's Avatar
As far as I know mig is good for light duty stuff and stick is for bigger/thicker metal. At least from my own back yard adventures so don't quote me. I'm also interested to know.
Michaelgoesrawr is offline
post #82 of 86 Old 10-02-2012, 05:44 PM
bigbossd1030
Stick can be stronger if it is done right. If you take a close look at the picture of the pitman, it obviously has undercut. The spots where you can see where his beads are, that is undercut. If you had 0% undercut, then it is stronger than mig. But with any undercut, your strength just jumped out the window, just like that pitman arm will soon. Also, stick is used when welding outside has to be done, no gases to blow away in the wind.
Go ahead and keep with your build as you will anyway, I am not going to continue to explain how this monstrosity is going to more than likely cost lives.
This is the only time I have ever given up on a Jeeper, well, A Jeeper knows when they are doing something wrong and dangerous. Your call, not mine. Good luck, hope you don't kill someone.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #83 of 86 Old 10-02-2012, 05:45 PM
bigbossd1030
Oh and his is a solid piece of steel, yours is weld, his will outlast yours anyday.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #84 of 86 Old 11-04-2012, 06:32 PM Thread Starter
fuzzy89
well been running for about 3 weeks now and finally found some tires close to home and after about a hour and a half of putting them on rims by hand it looks alot better(our tire machine is too small)
Before
After
Dad finding this is easier than tractor tires
In the light
fuzzy89 is offline
post #85 of 86 Old 11-04-2012, 07:58 PM
Ripper3494
i chucked a few things together when i did my build and regretted it a few months later... since then ive gone out and spent the couple hundred bucks extra and got parts that belonged together. if your going to half *** something its not worth doing. looks like you got a great jeep now that its running and driving and youve had a taste of the new setup, i would slowly start chipping away at things that need to be redone,.
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #86 of 86 Old 11-05-2012, 06:22 PM Thread Starter
fuzzy89
Ripper3494 thats my plan now start chippin away at her
Has anybody seen plans for a tube crossmember for the 205?
fuzzy89 is offline
Dana 30 to Dana 44 axle swap jjbtj TJ Wrangler Technical Forum 31 02-25-2014 05:38 PM
79 J10 Dana 44 axle swap to my 98 TJ scassedy TJ Wrangler Technical Forum 0 06-03-2009 06:56 PM
dana 44 axle swap bigsquat YJ Wrangler Technical Forum 24 09-19-2008 09:14 PM
Dana 44 axle swap Krisfyr TJ Wrangler Technical Forum 17 01-08-2006 08:14 PM
Dana 44 Axle Swap gigantorTRON YJ Wrangler Technical Forum 0 08-04-2005 12:20 PM
