Dana 44/60 Axle Swap - Page 5 - JeepForum.com
post #61 of 86 Old 09-30-2012, 07:46 PM
BlueRubiconrich
welding: I'm a welder and I have a 110 mig and a ACDC stick welder
a 110 is fine for somethings say sheetmetal light steel but when you want
things (LOL) to stay together you use a stick welder and not 6011 ether.
you use 7018.You should not weld a pitman arm. Spend the money and do it right, don't cobble it together.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #62 of 86 Old 09-30-2012, 07:55 PM
skyj
Originally Posted by fuzzy89
theres about 20 passes of weld on it laying one bead then wire wheeling it then laying another weld and so on
Oh well then carry on then. I don't know what I'm talking about.... 20 passes are you kidding me??
build thread:
skyj is offline
post #63 of 86 Old 09-30-2012, 08:08 PM
BlueRubiconrich
and what Rod are you using?
post #64 of 86 Old 09-30-2012, 08:28 PM
G30SFF250
I know you said you are a "welder" and all, but isn't the pitman arm cast ductile iron and requires preheating and a nickel rod?
Nothing is wrong with a 6011 rod when used correctly. To say use a 7018 rod and stick welding when you want things to stay together tells what kind of a "welder" you are.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #65 of 86 Old 09-30-2012, 08:52 PM
bigbossd1030
Ok... I couldn't go on anymore. That thing you call a pitman arm, is a deathtrap. If my boss ever saw me do anything like that, it would be my job. I have no idea where the person who "welded" that up, learned it was ok. What you did was make a piece of steel out of copperwire. This makes no sence. I agree with using smaw rather than gmaw. But this takes more patience, judging by those weld jobs, there has to be a lack of. If at all possible, smaw with 7018 or 7024 rod. If you really mean buisness. Or use a 240 V gmaw with .035 wire, I would run at least 25v and 454ipm wire speed. You will penetrate and fill with enough wire to avoid undercut. If you need to grind you don't know what you are doing. I build winch tractors and use this setting to weld 3/4 inch plate. But do NOT fill with passes to make a chunck of steel. The weld will not hold up. If you insist on trying to destroy someones life, go to a gravel pit, open her up do a few turns, see what happens. I hope you need an inspection after you are done.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #66 of 86 Old 09-30-2012, 09:01 PM
bigbossd1030
You are right, but a 6011 or similar rod is for light duty work. Not for this. And yes in normal situations, preheating and stabilized nickle rods should be used... but it can be done with a mig or stick. We don't weld much cast, but we preheat the part to 600 first. A nickle rod should be used though, but really, look at the pics and tell me its not a waste of time explaining how to do it properly. Its expensive to get everything, and requires a lot of time to heat and slow cool so it doesn't crack.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #67 of 86 Old 09-30-2012, 09:07 PM
G30SFF250
I agree with you, I was just referring to the previous blanket statement that I quoted.
post #68 of 86 Old 09-30-2012, 09:50 PM
bigbossd1030
I understand. I just can't get over those pictures, unreal.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #69 of 86 Old 09-30-2012, 10:07 PM
jason m
Nothing but the facts
jason m's Avatar
No pitman arm are forged steel and can be welded. This one the Op did looks like it has alot of slag pockets or voids which can leed to stress riser and fail, so I wouldn't trust it.
But to answer the question yes they can be welded and with any 70.000 tensle strength rod/filler.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is online now
post #70 of 86 Old 10-01-2012, 05:36 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Op, If this many people are concerned.... Time to slow down the build and redo. Start with the crossmember, order the right steering components. Overall, what you think is strong enough is not.
3" on either side, is not enough
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #71 of 86 Old 10-01-2012, 06:38 AM Thread Starter
fuzzy89
Its 7018 rod and the crossmember is temp anyway
fuzzy89 is offline
post #72 of 86 Old 10-01-2012, 10:23 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
These guys are trying to help you get it right and not kill yourself.
Ignore them at your own risk.
All you needed were leftovers from your local steel yard and 20' of 1.5" 1/4 wall dom and 4 Weld in bungs.
Pittman arm from a wagoneer, and one CORRECT high steer arm with studs and cone washers.
Save a life, do it right.
ratmonkey is offline
post #73 of 86 Old 10-01-2012, 12:46 PM
bigbossd1030
Originally Posted by ratmonkey
these guys are trying to help you get it right and not kill yourself.
All you needed were leftovers from your local steel yard and 20' of 1.5" 1/4 wall dom and 4 weld in bungs.
Pittman arm from a wagoneer, and one correct high steer arm with studs and cone washers.
x2
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #74 of 86 Old 10-01-2012, 05:17 PM
BlueRubiconrich
Yes I'm a welder and my words were a joke. "Stick things together" LOL
I was being funny and welding certain things are not.
post #75 of 86 Old 10-01-2012, 06:32 PM
skyj
xxx3
build thread:
skyj is offline
Dana 30 to Dana 44 axle swap jjbtj TJ Wrangler Technical Forum 31 02-25-2014 05:38 PM
79 J10 Dana 44 axle swap to my 98 TJ scassedy TJ Wrangler Technical Forum 0 06-03-2009 06:56 PM
dana 44 axle swap bigsquat YJ Wrangler Technical Forum 24 09-19-2008 09:14 PM
Dana 44 axle swap Krisfyr TJ Wrangler Technical Forum 17 01-08-2006 08:14 PM
Dana 44 Axle Swap gigantorTRON YJ Wrangler Technical Forum 0 08-04-2005 12:20 PM
