dana 35 swap - JeepForum.com
post #1 of 10 Old 08-26-2011, 03:55 PM Thread Starter
chrisharg82
dana 35 swap
Does anyone know if the Dana 35 from a 98 Cherokee will fit a 95 YJ without any modifications?
chrisharg82 is offline
post #2 of 10 Old 08-26-2011, 04:10 PM
jeepyj13
spring perches are mounted on a spring over axle configuration vs a yj spring under axle. shock mounts are mounted different. if you have the welding skills cut the perches off weld them under and cut shock mounts remount to yj specs. it would be easier to find another yj d35 and just put it under there
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #3 of 10 Old 08-26-2011, 04:12 PM
92 Green YJ
92 Green YJ's Avatar
what he said. and honestly, why bother? if your gonna change a whole axle, why not upgrade?
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #4 of 10 Old 08-26-2011, 04:41 PM Thread Starter
chrisharg82
Oh I agree and its in the works, just need a quick fix to get by
post #5 of 10 Old 08-26-2011, 04:45 PM Thread Starter
chrisharg82
I also have a intermittent clicking sound coming from the front right wheel area, my first thought is a bearing would all agree?
post #6 of 10 Old 08-26-2011, 05:09 PM
I8AHUMR
Ujoint?
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #7 of 10 Old 08-26-2011, 06:39 PM
Xpress
I have the same clicking noise from the front left. I think it's either the bearings in the hub or u-joints...
All about that unibody life.
Xpress is offline
post #8 of 10 Old 08-26-2011, 06:45 PM
jeepyj13
i have the same clicking noise too out of the right front. it could either be wheel bearing or ujoint. and having 33s mounted on 15x10 rims w/3.75 bs is not helping.
jeepyj13 is offline
post #9 of 10 Old 08-26-2011, 07:00 PM
jdubsjeep
U joint = clicking from front 99% time
jdubsjeep is offline
post #10 of 10 Old 08-26-2011, 09:47 PM Thread Starter
chrisharg82
Maybe I will go ahead and swap out all the ujoints the same time I am changing out my rear end. I found one out of a YJ with 4.56 gears and a lockright locker.
