Dana 35 repair? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Dana 35 repair?
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 06-08-2013, 07:40 PM   #1
herb97tj
Dana 35 repair?
Ok so I went mudding last weekend the jeep was running good for a few days after that. A few days ago I noticed a grinding noise coming from the rear diff. Didn't think to much abou it at the time. Last nite I pull out of my drive way n get about 50 feet n the rear wheels just locked up. Got it back in the drive way pulled off the diff cover n it was just gunk like the consistency of toothpaste. So I knew my pinnion seal was bad my question is I noticed like scar marks on the carrier from the pinnion. My plan is to thoughly clean all the crap out n put fresh gear oil in but am looking at a bigger issue than just the seal. I mean what caused the pinnion to make contact with the carrier. I check the pinnion gear n it's not damaged to bad.
herb97tj is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 08:08 PM   #2
Anticanman
RIP one good jeeper
Anticanman's Avatar
Its gone. Don't even think about the thousand dollars to repair it. You can replace it with another Dana 35 or fine a 8.8 if you plan on abusing the axle in the mud again.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 06-08-2013, 08:40 PM   #3
herb97tj
Yea im probably gonna go with the 8.8 since I will be putting a v8 with a turbo 400 in later this year. Still haven't decided if I'm gonna keep my NP231
Unread 06-08-2013, 08:43 PM   #4
Anticanman
RIP one good jeeper
Anticanman's Avatar
Might wanna do a hybrid 231c/j case. It'll make compatibility issues a lot easier to deal with.
Unread 06-08-2013, 11:28 PM   #5
lutzke21
lutzke21's Avatar
8.8, the best repair part/upgrade developed for the -35.
-Scott
'94 YJ on 35s
Sept '14 YJOTM
July '13 YJOTM
M C L M M
lutzke21 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:00 AM   #6
herb97tj
Ok so I already have a cv driveshaft so I'm gonna go ahead n get the adapter flange for the 8.8 but what about brakes? Just run a new line from cylinder? Just curious how everyone else routed there's.
Unread 06-09-2013, 08:08 AM   #7
Relicmoto
I can't see why you couldn't just replace the flexible line that runs from the hard line to the axle.
Relicmoto is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:18 AM   #8
Noltz
YJ Wrangler
There's an 8.8 in mine, and I used the stock 1999 ford flex line.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:40 AM   #9
herb97tj
Ok thanks for the info guys.
