Dana 35 Rear end - JeepForum.com
post #1 of 3 Old 06-19-2001, 06:48 PM Thread Starter
BigD1634
2012 KK Liberty
Dana 35 Rear end
I have a 95 YJ and I am putting a 3" lift on it this week. What gears are in my jeep and what tires do you think will be good. I don't off road as much as I would like to.
BigD1634 is offline
post #2 of 3 Old 06-20-2001, 07:55 AM
jeeptuff
I would guess you have 373's in that rear end, check the tag on the diff cover it should tell you. As for tire a 33 is tight with a 3" lift but will fit..
Eric
Once again Jeepless in Seattle
jeeptuff is offline
post #3 of 3 Old 06-20-2001, 01:20 PM
Tonka
2015 JK Wrangler
is your jeep 4 or 6 cyl? if it's a 4 cyl the its 4.11 which is often just referred to as 4.10's
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
Dana 35 C vs Dana 35 / counter wights on rear hub Austin77 YJ Wrangler Technical Forum 4 02-03-2009 09:56 AM
Dana 30 Front, Dana 60 Rear???? MMerrick YJ Wrangler Technical Forum 7 01-07-2008 12:51 PM
(2) Dana 44s or Dana 44 in rear and 35 front Ethan03 TJ Wrangler Technical Forum 27 06-14-2006 12:04 AM
Can REAR Dana 35 4.11 work with FRONT Dana 30 4.10 4.2-blackone YJ Wrangler Technical Forum 11 04-03-2006 11:22 PM
4:10, 33's, Dana M35 Rear, Dana 30 Front Jeeper-4-Life TJ Wrangler Technical Forum 1 02-10-2004 03:48 PM
