Dana 35 Pinion Seal replacement question - JeepForum.com
post #1 of 31 Old 03-11-2009, 09:27 AM Thread Starter
95wrangler4life
Can someone give me the quick run down on replacing my pinion seal on the 35? I still drive mine on the road so it needs done right. My buddy said when he did his (CJ) that he just pulled the yoke, pulled the old seal, seated the new seal and reinstalled the yoke and never had to mess with the gears! But wasnt sure this would be good for driving on the road, since his CJ is trailered!
Thanks
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #2 of 31 Old 03-11-2009, 09:31 AM
obsessedjeeper
obsessedjeeper's Avatar
2013 WK
sounds like all i did to mine when i replaced it. its pretty straightforward
Keep on Jeepin
95 YJ
98 ZJ
obsessedjeeper is offline
post #3 of 31 Old 03-11-2009, 11:59 AM
cmsurfer
Do yourself a favor a get a seal puller. I replaced the pinion seal on my D35 last year and went through hell trying to get the old one out. I ran to Napa, got a seal puller, and had it out in about 10 seconds.
cmsurfer is offline
post #4 of 31 Old 03-11-2009, 12:04 PM
lonestar_yj
just changed mine last week, about a 30 min. job. pulled the drive shaft off. used a 1/2 inch impact gun to take the nut off and used a screw driver and a little pry bar to pop the seal out, taped the new one in and used the impact gun to put the nut back on
93 wrangler sahara, 4" lift, 1" shackles, 33x12.5 maxis buckshots on crager rims, hm front,back bumper,towbar, hand throttle
lonestar_yj is offline
post #5 of 31 Old 03-11-2009, 12:10 PM
Tulsachokehold
Thanks
that is EXACTLY how it is done. You need to be sure you drive the seal in straight. if it s crooked at all you will be replacing it again in no time.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline
post #6 of 31 Old 03-11-2009, 01:35 PM Thread Starter
95wrangler4life
thanks guys, appriciate it, he just wanted to be sure we didnt have to worry bout messin with gears or anything!
Build thread:
post #7 of 31 Old 05-15-2009, 08:57 AM
Nerv
I've been told not to use an impact gun, could possibly damage the pinion.
Follow these simple steps
1. Mark the driveshaft to the yoke before removing the driveshaft. Careful not to release the needle bearings in the u-joint.
2. Mark the pinion, nut and yoke with a straight line for re-installation later.
3. Remove the pinion nut.
4. Pull seal out, lube the new seal before installing it
5. Reinstall the pinion nut and tighten to the same location as before, then turn 1/8 of a turn more, this will preload the bearings in the pinion shaft. [Use red locktite if re-using same nut]
6. Reinstall yoke and driveshaft to same position as before. [Use some sealant on the inside of the yoke to keep oil from seaping through the splines.
That's it!
Nerv is offline
post #8 of 31 Old 05-15-2009, 10:10 AM
jaywiz1977
if it's got a leak thats a good time to upgrade to a better axle!thats what i told my wife would cure mine from putting that spot on the drive....that d35 has never leaked on the drive since!
There are alot of different people in the world out of all of them,it's the normal ones that scare me the most!
jaywiz1977 is offline
post #9 of 31 Old 07-04-2010, 04:42 PM
mmarmouz
well, i have to change my pinion seal soon, do i have to remove the differential cover and flush the old fluid before doing that ? or the seal can be changed with the oil in the differential ?
i have a dana 35 on a tj
mmarmouz is offline
post #10 of 31 Old 07-04-2010, 06:49 PM
jdubsjeep
no need to drain, unless the oil is milky from water or has a lot of miles on it. I always put a catch pan under my work so if I loose some oil it won't leave a mess.
jdubsjeep is offline
post #11 of 31 Old 07-04-2010, 08:59 PM
mmarmouz
thank you, well now i guess i have work to do
mmarmouz is offline
post #12 of 31 Old 09-15-2010, 03:34 PM
spankinkopita
Know this thread is old
I just replaced the seal on my 35, when I did it I later discovered a part in the box I did not remove during the breakdown but looks like a collapsible pinion spacer, should I have put that in?
spankinkopita is offline
post #13 of 31 Old 09-15-2010, 04:25 PM Thread Starter
95wrangler4life
that is the crush sleeve, which is the reason behind not using a impact gun on the nut when putting it back on and not over torquing.
Build thread:
post #14 of 31 Old 09-15-2010, 04:40 PM
spankinkopita
Aw Shucks
Looks like I'll be awaiting a new seal so I can pull it and reinstall. Does it go on between the seal and shaft or the pinion and seal?
post #15 of 31 Old 09-15-2010, 06:18 PM Thread Starter
95wrangler4life
hopfully someone with more knowledge will chime in, when i did mine, i did not replace the crush sleeve so i have no clue, and it worked fine for a while.
Build thread:
D30 pinion seal replacement jeep_chinto TJ Wrangler Technical Forum 9 03-13-2007 08:20 PM
Pinion Seal Replacement Question bruker TJ Wrangler Technical Forum 3 10-02-2006 01:48 PM
pinion seal replacement Muddeprived TJ Wrangler Technical Forum 38 09-07-2005 04:56 PM
Dana 44 Pinion Oil Seal Replacement??? pbungar TJ Wrangler Technical Forum 3 08-23-2005 09:27 AM
Pinion seal replacement boomhower YJ Wrangler Technical Forum 3 08-10-2005 08:37 AM
