Dana 35 interchangability 93 to 89? - JeepForum.com
post #1 of 10 Old 04-01-2013, 12:30 PM Thread Starter
mrdeath2000
Are they interchangeable throughout the model years? (87-95).
I know some of the older ones had different looking brake drums, but I think that's because those were non-c-clip ones right? or was that just a freakish finned thing from the 80's? lol
Not that non-c-clip would matter because it would be a whole axle swap, but the 93 should bolt right up to everything, spring plates, brake lines & driveshaft, right?
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #2 of 10 Old 04-01-2013, 12:32 PM
Jeepsr4me
93 saw a U joint change, so you may or may not need a conversion Ujoint. But other than that it will bolt right in.
Most auto parts places sale that joint and keep it in stock.
Jeepsr4me is online now
post #3 of 10 Old 04-01-2013, 12:35 PM Thread Starter
mrdeath2000
awesome! thanks bro!
post #4 of 10 Old 04-01-2013, 01:08 PM
crackedcornish
may also be a difference in the e-brake cable length between the older set up and the newer one
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #5 of 10 Old 04-01-2013, 02:43 PM
Flajeeper1
1987 YJ Wrangler
You will probably need the 1310/1330 bastard U-joint.
http://www.4wheelparts.com/Drivetrai...pn=D%2fS5-134X
Flajeeper1 is offline
post #6 of 10 Old 04-01-2013, 02:44 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Skip the ujoint change and just swap the yokes. Zip them off and then back on again.
Luck Favours The Prepared
Anticanman is offline
post #7 of 10 Old 04-01-2013, 02:46 PM
Flajeeper1
1987 YJ Wrangler
Yeah. six, one half dozen the other. He's putting a D35 back in.......
post #8 of 10 Old 04-01-2013, 03:35 PM Thread Starter
mrdeath2000
Actually I am selling my old 93 4.10 D35 to someone who has a broken 89 3.55 YJ. I know my rear yolk is 1310/1310, so we're good there.
Last edited by mrdeath2000; 04-01-2013 at 03:36 PM. Reason: 93 not 92... stupid brain.
post #9 of 10 Old 04-01-2013, 03:42 PM
Flajeeper1
1987 YJ Wrangler
What gears do you currently have in the D30? If they're 4.10s then your new D35 with 3.55s won't work if you plan to use 4 wheel drive. You can't mismatch gear ratios. Before I'd go to the trouble of gearing a D35 either buy one with 4.10 gears or upgrade to a 8.8. You can find 8.8s with 4.10 gears of you look hard enough.
post #10 of 10 Old 04-01-2013, 03:46 PM Thread Starter
mrdeath2000
I have 4.88's in my D30 and 8.8.
Guy is interested in just the D35 with 4.10s. I have tried to explain to him that he wants my D30 Carrier and 4.10's as well for the front. even if he doesnt do anything with them now, he'll want them later.
