DANA 35 differential question - JeepForum.com
post #1 of 15 Old 04-19-2013, 08:17 PM Thread Starter
kputcha1
I have a 4 cylinder 5 speed 1995 YJ and I was working on the rear DANA 35 differential and I broke the pinion shaft lock bolt in the differential case. I tried drilling out the bolt but I may have toasted the threads which would hold the bolt in the case. The pinion and ratio ring are okay, but I think I'll need to replace the case. This may be a stupid question but, I was wondering if I were to buy a used (DANA 35) rear differential case that was on a 1991 6 cylinder, 5 speed YJ (with 3.07 gear ratio) would I be able to change out the gears in the case back to 4.11? I greatly appreciate any advice at this moment.
kputcha1 is offline
post #2 of 15 Old 04-19-2013, 08:25 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
First of all, welcome.
Second, no. There are two things holding you back. First is the fact that the carriers are not interchangeable on two levels. There is a carrier break from 3.73-4.10. There is also a difference between the pre '93 and post '93 Dana 35 carriers in terms of gears. Second is not an insult, but the expertise it takes to install gears is beyond even my scope of wrenching to be done on a whim.
Find a matching axle with 4.10 and hang on to your original rear yoke because you may need to swap it onto another axle.
Luck Favours The Prepared
Anticanman is offline
post #3 of 15 Old 04-19-2013, 08:53 PM Thread Starter
kputcha1
Thank you very much for you input. I would prefer not to replace the entire axle due to the expense it would cost me. Money is a bit tight for me at the moment, so do you think keeping an eye out for a used DANA 35 carrier with the 4.10 gear ration which fits my wrangler model sound practical?
kputcha1 is offline
post #4 of 15 Old 04-19-2013, 09:39 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's going to cost a whole lot more to set up the gears than to install the whole axle.
post #5 of 15 Old 04-19-2013, 09:40 PM
Kaiser-Willys
If you change the rear gear ratio you HAVE to change the gears in the front diff at the same time. Not doing so will cause serious drivetrain damage.
If you did booger up the threads for the cross pin shaft retainer bolt, I would pull out the carrier and Heli-coil that hole.
Good luck!
Kaiser-Willys is offline
post #6 of 15 Old 04-19-2013, 11:34 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
To say you HAVE to, is inaccurate. Here's a couple reasons why......if he's running stock driveline components, as long as he doesn't put it into/drive it in 4WD, he'll be fine since no power is being applied to the front axle. That, or simply remove the front drive shaft & you'll eliminate a possibility of having a ratio difference issue.
Make sense?
Joe Dillard is offline
post #7 of 15 Old 04-19-2013, 11:48 PM
ghetdjc320
Just FYI the break on ratios for the dana 35 is 3.55 and 3.73 on the dana 30. Dana 35 3.55 and up and 3.54 and down.
-DJC
ghetdjc320 is offline
post #8 of 15 Old 04-20-2013, 12:46 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Right. Typed it wrong. Thanks!!
post #9 of 15 Old 04-20-2013, 05:13 AM
bogleparsons
I have a Dana 35 sitting in my garage complete brakes to brakes.
Too bad you can't come get the damn thing.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #10 of 15 Old 04-20-2013, 08:12 AM
soonermatt
To clarify on price: I sold my functional, 4.10 Dana 35 for $100 outright.
Cost to install gears in new axle: $200
Cost of new gears: $200
Cost of used axle: $250
Cost of bearings, inner and out: $150
Oil: $15
And there's even more
As you can see, dicking with axles gets expensive and your Dana 35 is cheap to replace. Put a WTB on Craigslist and local jeep clubs.
soonermatt is offline
post #11 of 15 Old 04-20-2013, 09:21 AM
Bong_Holyeo
I agree a dana 35 is cheap to replace because no one wants them. I had to throw my dana 35 with 4.10 gears in the dumpster after my 8.8 swap because it sat on Craigslist for 6 weeks at 50$ with no interest at all.
However i will give you some advise that i did not listen to soon enough, DO NOT SPEND MONEY ON A DANA 35! 4.10 gear 8.8 out of a explorer has disk breaks and goes for 150$ around here
Bong_Holyeo is offline
post #12 of 15 Old 04-20-2013, 09:21 AM
bogleparsons
Oil: $15
They want $1600-1800 to do my regear at the local 4x4 shop
post #13 of 15 Old 04-20-2013, 11:42 AM
Steve707
Wow, i thought it was steep here at 2-300 per axle in labor. Does that include an air locker or something extra?
Steve707 is offline
post #14 of 15 Old 04-20-2013, 03:13 PM
TrentYJ
300 would be on the cheap for around here. Cheapest I could find was 600 per axle for labor only
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline
post #15 of 15 Old 04-22-2013, 11:44 AM
Flajeeper1
1987 YJ Wrangler
$600 .... wow. I just had a Auburn electric locker installed and regeared an 8.8 to 4.10s for $250 at an axle shop. I agree to drill the hole and install a helocoil. There's no stress on the bolt when operating and it's cheap to do.
Flajeeper1 is offline
