Quantcast dana 35 clunking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > dana 35 clunking
Great deals on Mickey Thompson Tires @ Jeephut.comOfficial Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFG
Old 11-02-2008, 10:33 AM   #1
PatrickMintun
dana 35 clunking
I just bought a nother YJ its a 1990 w/2.5 5spd has lots of upgrades black diamond coil over conversion,and has warn hubs all around. I bought from my buddy. he thought it needed a trans I drove it yesterday. clunking from rear end. has 4.56 gears and open diff. looks like side and spider gears are bad one has bad tooth, Question is what was done when hubs were installed can I just replace side and spider gears should I add a lock right locker? has no c clips are these spider and aide gears part of the hub kit? did this diff have c clips? I know axels are part of hub kit, did they change spiders and side gears
PatrickMintun is offline   Reply With Quote
Old 11-02-2008, 10:37 AM   #2
BeerJ
spider gears are a seperate kit, and in my opinion I wouldnt lock the 35
[QUOTE=toates89;6382846] Now i am in love with beer. I have had around 100 beers.[/QUOTE]
BeerJ is offline   Reply With Quote
Old 11-02-2008, 03:12 PM   #3
ScotZ
American to the Bone
ScotZ's Avatar
Not to be insulting here but have you checked the U-Joints. That is normally where you get a clunking sound. Just a thought
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline   Reply With Quote
Old 11-02-2008, 06:30 PM   #4
PatrickMintun
i
pulled cover and found spiders are tore up major pits in them one tooth on drivers side looks like its cracked all the way across tooth what? about a lock right?
Old 11-03-2008, 12:31 AM   #5
RikRotorhead
Rik for President in 2012
RikRotorhead's Avatar
The spyders are easy to replace. Buy new gears and throw them in.
Took me all of ten minutes to replace the two floating gears. If you need to replace the axle shaft spyders, It's pretty easy to do that as well..
But if you want to eliminate the D35 for a stronger axle, maybe this is your window of opportunity. '95 to '01 Ford Explorer rear end is the most popular upgrade for the YJ.
Zombies hate fast food.
Guns don't kill people, guns kill dinner.
RJC#512
RikRotorhead is offline   Reply With Quote
Glock Forum
