Dana 35 C vs Dana 35 / counter wights on rear hub - JeepForum.com
post #1 of 5 Old 02-03-2009, 09:20 AM Thread Starter
Austin77
I am currenly in the process of painting my alumimun rims. I just noticed that the drivers side rear drum has counter wights. Also my axle that someone else installed is a Dana 35c, out of a 98 TJ. Any thoughts on this. Is the Dana 35c more dureable than the Dana 35? I have had my tires balanced, and the counter wights were put on the inside of the rim as normal. Are the one that are on the drum factory? Or should I remove them? I relize I could of used the search feature to answer half the quistions, I trying to save time got pick my son up from school at 4:30. Thanks alot guys
YJ under construction
Austin77 is offline
post #2 of 5 Old 02-03-2009, 09:48 AM
LandoCommando
I believe there is no difference between the 35 and the 35c. And your YJ most likely came with a 35c.
The "C" just stand for custom because they weren't shipped complete from Dana and were fully assembled by Chrysler.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline
post #3 of 5 Old 02-03-2009, 09:52 AM
idaholtby
Those weights are just to balance the drum by it'self. I would leave them alone.
idaholtby is offline
post #4 of 5 Old 02-03-2009, 09:56 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Those weights are normal. The drums are balanced from the factory because casting is not perfect.
The axle installed is the same as the axle you have in your YJ. You DO have a dana 35C.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 5 Old 02-03-2009, 09:56 AM Thread Starter
Austin77
Thank youll for the quick responces. Learn something new every day.
Austin77 is offline
Dana 44 front Dana 35c rear? yghong2204 TJ Wrangler Technical Forum 23 12-30-2009 02:04 PM
(2) Dana 44s or Dana 44 in rear and 35 front Ethan03 TJ Wrangler Technical Forum 27 06-14-2006 12:04 AM
Can REAR Dana 35 4.11 work with FRONT Dana 30 4.10 4.2-blackone YJ Wrangler Technical Forum 11 04-03-2006 11:22 PM
Dana 25 front and Dana 41 rear MNKMcNeilly YJ Wrangler Technical Forum 5 02-03-2006 02:13 PM
4:10, 33's, Dana M35 Rear, Dana 30 Front Jeeper-4-Life TJ Wrangler Technical Forum 1 02-10-2004 03:48 PM
