Dana 35 C-clip Axle removal - JeepForum.com
post #1 of 3 Old 08-21-2002, 02:58 AM Thread Starter
Paulwpetrea
Paulwpetrea's Avatar
Guys/gals:
I need a little information if you would, please?
I am about to take two ('90 and '95) Dana 35 C-clip axles apart. Does anyone know of a writeup, tech page, or would you post the details for doing so? Tools/sizes if possible.
I am going to take the spiders out of one of them. I am then going to take a broken E-Z locker (I think it's broken anyway) out of the other and replace it with the spiders from the first one.
I want to do this on this upcoming weekend.
Thanks.
Paul
Paulwpetrea is offline
post #2 of 3 Old 08-21-2002, 07:28 AM
RodeoRob
RodeoRob's Avatar
A quick overview for ya....
0.) put vehicle on jackstands, remove wheels, drums, take off cover, drain, blah, blah, blah.
1.) remove the cross pin retaining bolt (this is a small wrench, like 5/32s or something), slide out the cross pin.
2.) now the axle shafts will push in slightly, enabling you to remove the c-clips.
3.) rotate the carrier around and the top spiders will slide out then enabling you to remove the side spiders.
Thats all there is too it, sounds simply eh?
You shouldn't need much more than a simple set of sockets/wrenchs. The of course gear oil and RTV to seal it back up.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 3 Old 08-21-2002, 10:54 AM
moabster
moabster's Avatar
2011 WK
This is from Stu Olson's Jeep Site (I like this site)
D35 Axle Removal
Have Fun
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
Rear axle bearing problem on dana 35 W/O c clip bilwil YJ Wrangler Technical Forum 6 04-03-2012 06:02 AM
Dana 35 non c-clip rear axle crackles when turning. Siller YJ Wrangler Technical Forum 5 08-23-2009 09:00 AM
'97 TJ 2.5 l.Rear Axle DANA 35 C-clip or not???? Swedejeeper TJ Wrangler Technical Forum 6 12-22-2008 04:56 PM
Dana 30 Axle with C clip DaSham58 YJ Wrangler Technical Forum 7 11-29-2006 06:56 PM
Requesting Axle Help: Dana 35c (c-clip) rear differential ... Paulwpetrea YJ Wrangler Technical Forum 7 08-27-2002 08:16 PM
