#1 | |
Dana 35 axle ?
I bought some spare inner axle shafts but i have a question.
What are the mesurements of the shafts i know one is shorter than the other but the ones i received are the same length. What by chance is the drivers side suppose to be and what is the passenger side suppose to be.....in length. Thanks
#2 |
When you say inner axle shafts I assume you mean for a Dana 30 and not a 35. I don't know the measurements but the shafts should be nearly the same length, the one with the bigger splines on the end is for the passenger (long) side. The big splines mesh with the 4wd shift collar.
1995 YJ Rio Grand - work in progress |
#3 |
No,
I do mean the Dana 35 the shafts in question are known as one being longer than the other but which one is drivers side and which is the passenger side either the longer one goes into the drivers side or the shorter one and what are their measured lengths. for proper I.D. (identification) |
#4 |
Check Quadratec's replacement parts section. They list the length for different years. Your 1991 D35 shafts will be _slightly_ different than a 1993-1995.
#5 |
Free clues & suggestions
Right hand non ABS = 29"
Left hand non ABS = 30.5" Right hand w/ABS = 29.25" Left hand w/ABS = 30 11/16" |
#6 |
thank Joe,
I knew there was something about the different years but was not sure. I'll be in San Diego on business from July to sept sometime maybe we can go Wheeling when i'm out there. thanks again |
#7 | |
Maybe?????? PM me your number & I'm sure we can put some wheelin' trip(s) together.~874 pages & 13,000+ posts so far Us San Diego folks tend to get things done & go wheelin. ![]() Many of these folks are good friends of mine. http://www.jeepforum.com/forum/f262/san-diego-area-214660/index874.html |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
