dana 30yj to tj passenger shaft seal problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > dana 30yj to tj passenger shaft seal problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCustom Tire covers for your Jeep at Jeephut.comThe Spring DynoMax rebate is here for 2015!
Unread 02-27-2015, 08:37 PM   #1
Acorrado
I just got a tj 27 spline passenger shaft for my 95 yj dana 30. slid in smooth. took out the star round gear thingy and just put the control plate back on. now im leaking quite a bit of fluid out of the tube at my passenger wheel. i know how to remove a carrier and all that good stuff. already re-geared and locked my front end. did i damage a seal when installing? do i need a different size seal? is there a important seal where that air control module is? if i do need new seals can you tell me specifically which ones i need and can i get them from a local parts store? and what they look like because advance auto employees tried to sell me a pinion seal saying it was the right one. i could be wrong but i think the seal is different. but the oil is still rollin out so any help is appreciated. pictures are awesome!!! visual learner here.
Acorrado is offline   Reply With Quote Quick reply to this message
Unread 02-27-2015, 09:02 PM   #2
jbolty
jbolty's Avatar
Napa # 11800 You need to pull the carrier and put it on the passenger side, inside the pumpkin
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:14 AM   #3
pete1991YJ
^^^ There's your answer. BTW, Welcome to JeepForum, you've just found one of the best jeep sites anywhere!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:19 AM   #4
Acorrado
Is that a special seal or just a tj seal?
Unread Yesterday, 11:14 AM   #5
jbolty
jbolty's Avatar
It's the seal that fits and works
Unread Yesterday, 03:13 PM   #6
The_Goob
Hell on Wheels
The_Goob's Avatar
Like said above, napa 11800 at the pumpkin. the old seal at the CAD housing is a different size and will not seal on a tj shaft. The shafts are a different thickness
The_Goob is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:19 PM   #7
timatoe
timatoe's Avatar
It's just a seal. Don't try and tell someone "I need xxx seal for xxx vehicle in xxx location" type of thing. Go to Napa and tell them you need part number 11800.
timatoe is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 03:27 PM   #8
The_Goob
Hell on Wheels
The_Goob's Avatar
If you mod your jeep enough then most parts end up being bought like that, with a part number in hand already!
"That part isnt for a jeep its for a 78 f-250" <--Yes I know just get it.
Unread Yesterday, 08:26 PM   #9
timatoe
timatoe's Avatar
Exactly, I hate the.....
"I need a part # XYZ...."
"What's it for?"
"Don't know"
"You don't know what it's for?"
"Yes I do, it's for a '90 Jeep Wrangler with a fuel injected 4.2, four wheel disc brakes, with an onboard air compressor, electric fan and air lockers."
"I don't even show those options."
"I know, can I have a part #XYZ?"
