dana 30 u-joint caps - JeepForum.com
post #1 of 12 Old 05-03-2007, 03:45 PM Thread Starter
MN_Sasquatch
how do you get them off and do the just slide through, it looks like they have a lip that sits on the outside of the axle shaft
MN_Sasquatch is offline
post #2 of 12 Old 05-03-2007, 03:50 PM
OhioYJ
My Changing Wheel Joints Writeup.
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things.
-- Mike
OhioYJ is offline
post #3 of 12 Old 05-03-2007, 03:54 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
http://www.jeepforum.com/forum/f12/axle-ujoint-replacement-yj-dana-30-a-360209/
And mine
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #4 of 12 Old 05-03-2007, 04:13 PM Thread Starter
MN_Sasquatch
ok, so do the caps slide through then?
post #5 of 12 Old 05-03-2007, 04:33 PM
jipjip
jipjip's Avatar
READ THE WRITE UP'S!!!!!
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #6 of 12 Old 05-03-2007, 05:40 PM
mmasuperman12
there are C clips on the inside i believe but if you get those out then yes they slide out, read those write ups though they saved me big time.
95 YJ 4banger 4 inch RC lift 1.25 inch BDS shackle lift 33" trxus M/T's on black steelies SOLD..DAMMIT!
Jeep drivers who dig Country Music member #12
1998 XJ - beginning the revival.
mmasuperman12 is offline
post #7 of 12 Old 05-03-2007, 07:58 PM
iwishihad1
any way you can bend the ears when using a vice? i had a friend doing his the other day with a vice and when he went to put the new u-joint in, both sides were completely in, but the u-joint stuck out about 1/8 of an inch??
iwishihad1 is offline
post #8 of 12 Old 05-03-2007, 08:08 PM
Tomb Raider
Addicted...
Then he had the wrong joints.
post #9 of 12 Old 05-03-2007, 08:24 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
it's possible, but it would be very obvious if they're off that far. i'm with Tomb, he probably got the wrong joints. either that or it just looked like they were all the way in and he had a needle or two out of position and holding the cap out a bit. happens all the time.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #10 of 12 Old 05-04-2007, 06:32 AM
Tulsachokehold
here is another question for him... Yeah, the guy may have been using the wrong Ujoint. But WHY was he replacing them to begin with? Did he break a Ujoint in that axle? blowing a Ujoint can totaly fook up the lobes on the axles.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline
post #11 of 12 Old 05-04-2007, 08:56 AM
iwishihad1
no..but they were really going bad. i could place my fingers on the joint, and wiggle it by hand
post #12 of 12 Old 05-04-2007, 04:28 PM
bharris68
Daily Driver
Fabulous write ups, gents. Thanks much. I'm tearing down and rebuilding a set of '73 Wagoneer Dana 44's (QuadraTrack case - soon to be a Dana 18 with Warn Overdrive) and this is on the list of stuff to do. Have parts, budgeting time
bharris68 is offline
stuck u joint caps front D.S. bremz8 TJ Wrangler Technical Forum 3 07-07-2009 08:23 PM
Dana 30 protector caps for hubs cemcjoe YJ Wrangler Technical Forum 1 05-10-2009 07:17 PM
'97 TJ rear universal joint caps cybervyk TJ Wrangler Technical Forum 3 04-20-2009 07:35 PM
torque specs on dana 30 bearing caps??? eng4safd YJ Wrangler Technical Forum 2 03-19-2007 04:44 PM
U-joint Caps Stuck pharmacist25 TJ Wrangler Technical Forum 4 04-13-2006 10:45 PM
