dana 30 as rear axle? - JeepForum.com
Closed Thread
post #1 of 21 Old 08-04-2007, 02:51 AM Thread Starter
richchs62
so after searching about the dana 30 axle, and finding that everyone says it seems to hold it 's own decent enough... i have a question...
if the dana 30 is a decent axle and if jeeps have them in the front... is there a way to make the dana 30 into a rear axle? if its even cost efficient...
my plan is to run 33"s no bigger, and just mild wheeling... anyone have aany other sugestions for a cheap medium duty rear axle?
1990 wrangler yj 2.5
jobs in progress - S.O.A, V8 swap, manual to auto , coporate 10 bolt axles..
richchs62 is offline
post #2 of 21 Old 08-04-2007, 04:53 AM
Prowler
Deffinetly not worth it even if it can be done. Better off getting an 8.8 out of an explorer.
4.2 EFI - Pacesetter header - Flowmaster - 4.5" RE XD - RE Monotubes - 35" Trxus M/Ts - 4.10s - D30 Aussie - 8.8 Trac Lok - NV3550 - Centerforce Dual Friction - B&M Shifter - ARB Snorkel - Livewires - M8000 - Duralined interior - custon front bumper - custom brush cables - HiLift on the hood with lights
"Don't follow me, You won't make it!"
Prowler is offline
post #3 of 21 Old 08-04-2007, 05:08 AM
JFM626
JFM626's Avatar
Dana 30 has a smaller ring gear (7.20) than a 35(7.56), cost effective, no ; Would need new axle tubes, perches etc etc, and try to find a ring and pinion for a 30 for a rear diff. Unless your 35 is pranged up completely, continue using it, When it breaks then, either replace it with another from the breakers, or upgrade. Mild wheeling, if that's what you are doing, should be fine.
JFM626 is offline
post #4 of 21 Old 08-04-2007, 06:47 AM
KUJeeper82
so is the d30 considered so tough strictly because four wheel drive is used so little in a vehicle's life? (for most people that is)
KUJeeper82 is offline
post #5 of 21 Old 08-04-2007, 08:27 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Take just one moment and consider what you are wondering about......
Hmm...you'll be removing the knuckles, ball joints, inner C's etc and then have an axle that is WAY too narrow. This is an extreamly poor starting place while building an axle be it front or rear. Get the picture?
The HPD30 can be built to survive some tough stuff - but it's a good idea to have an experianced driver behind the wheel who knows it's limitations and doesn't flog it like it's beefier than it is.
Joe Dillard is offline
post #6 of 21 Old 08-04-2007, 09:57 AM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
the reason it isn't a bad axle up front is because it does not have to deal w/ all the torque that the d35 deals with. i've never heard anyone consider this and considering that the pumpkin isn't even remotely close to center it would just be a serious waste of time and money.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #7 of 21 Old 08-04-2007, 10:17 AM
Axl Jack
Ford 8.8 Its the cheapest way to add a lot of strength to your vehicle. (Assuming you don't have to regear.) Why? Because its almost a completely bolt on application. As long as you can turn a wrench, you can get it done. If you don't have a welder, find a friend who does. At the very worst you might have to pay a shop to weld those spring perches on. But if you do all the measuring work and just bring the axle to the shop, I can't fathom anyone charging you more than a few bucks.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #8 of 21 Old 08-04-2007, 12:36 PM
goatboy
Good question...but there are a lotta economical solutions out there that would preclude this swap... Unless you are thinkin' along the lines of a four wheel steering system! Now THAT I'd like to see!!!
goatboy is offline
post #9 of 21 Old 05-08-2013, 10:28 AM
dukeryder
The strength of a Dana 30 in a YJ is the use of a reverse cut ring and pinion. The ring and pinion are stronger when they are reverse cut in front axles.
dukeryder is offline
post #10 of 21 Old 05-08-2013, 10:43 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by no1outlaw View Post
My 88 cheokee 2 wd comes from the factory with a dana 30 307 gears in the rear
Welcome to the site. I think your first post should have been after you read the FAQ in the Cherokee section and not have revived a six year old dead thread to post incorrect information. Kudos on searching though, its a lost art.
The high pinion doesn't hurt either.
Luck Favours The Prepared
Anticanman is offline
post #11 of 21 Old 05-08-2013, 11:05 AM
YJames90
YJames90's Avatar
D30 = 4 wheel steering !!
My 2.5 to 4.3 swap thread
YJames90 is offline
post #12 of 21 Old 05-08-2013, 12:34 PM
bogleparsons
exactly what i was thinking lol
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #13 of 21 Old 05-08-2013, 12:37 PM
sjones26573
No it doesn't.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #14 of 21 Old 07-04-2013, 12:31 PM
nekamc
You guys are looking at the wrong Dana 30. You guys are saying how much work your goin to need to do this correct but jeep already had Dana 30 rear ends in there jeeps my 1970 jeepster has factory Dana 30 rear end and its hasn't falled me yet.
nekamc is offline
post #15 of 21 Old 07-04-2013, 03:00 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
The only thing common between this thread and a Dana 30 - they both need locked!
-John-
johnboy68 is offline
Closed Thread
Anyone looking for a TJ Dana 44 rear axle? Wheelin98TJ Wrangler General Discussion 8 07-31-2008 07:38 AM
Dana M35 Rear Axle? map7711 YJ Wrangler Technical Forum 3 03-02-2006 12:45 PM
Rear Axle: Super 35 vs. Dana 44 jeepman83706 TJ Wrangler Technical Forum 5 06-07-2005 01:36 PM
Dana 44 Rear Axle oil seep? MotorRad TJ Wrangler Technical Forum 2 07-22-2003 05:21 AM
