dana 30 question - JeepForum.com
post #1 of 9 Old 05-15-2010, 06:20 PM Thread Starter
bigred94
dana 30 question
ok so my front ends blown. its a 410 axle i have a posi lock its open.so im kinda tight on money right now i cant aford a locker and need some help. i have a complete 307 front is there a carrier break on the fronts? i have blown spiders they dont spin its pretty much locked right now what will happen if i weld the front into posi? i have the posi lock i know the front drive shaft will aways spin. or could i take the spiders from the 307 and put them in?
bigred94 is offline
post #2 of 9 Old 05-15-2010, 06:24 PM
Area.3.Fiftyone
IIRC: 3.54 and down and 3.73 up is the carrier break.
You should be able to use the spiders though. AFAIK they are the same.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 9 Old 05-15-2010, 11:48 PM Thread Starter
bigred94
thats what i figured so are the spiders differat too?
bigred94 is offline
post #4 of 9 Old 05-15-2010, 11:52 PM
80cj
80cj's Avatar
1980 CJ5
The spiders should be the same as long as both are Dana 30's with open diffs.
80cj is offline
post #5 of 9 Old 05-16-2010, 07:11 AM
HARLEYX2
1987 YJ Wrangler
Just dont have different gear ratios from front to rear.
HARLEYX2 is offline
post #6 of 9 Old 05-16-2010, 10:34 AM
RockWoRM
RockWoRM's Avatar
just a thought... if at all possible, look for a P-n-P '95 banger 4.10 axle as a replacement. It will have the larger u-joints. The posilok can be swaped over. It will cost you more in parts to re-build the 307 axle than your current one.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #7 of 9 Old 05-16-2010, 09:21 PM Thread Starter
bigred94
ok i all realy have 410s in it was a 4bannger in its life. so i was just gonna switch spiders and the outer pinion bearin. and how do you replace the pass side axle seal? please post pics of it
bigred94 is offline
post #8 of 9 Old 05-16-2010, 09:41 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If you know how to set-up R&P gears, you are ahead of the game.
But, if you knew how to do that, you wouldn't be asking any of these questions.
You are looking at a few hundred $ to do that.
And the search function here can be your friends.
The very first link in that search was done by my friend Stu. I highly recommend you study/read thru his site. LOTS of info.
Google
Joe Dillard is online now
post #9 of 9 Old 05-17-2010, 06:36 PM Thread Starter
bigred94
yes i can do r&p and im not looking forforward to doing the seal at all.
bigred94 is offline
dana 30 and dana 35 carrier question BigBlackTJ2010 TJ Wrangler Technical Forum 23 02-27-2016 01:12 PM
Dana 35 to Dana 44 swap question? Grim Jeeper TJ Wrangler Technical Forum 38 01-31-2014 03:36 AM
Dana question jkoffroadin JK Wrangler Technical Forum 14 08-13-2009 05:48 PM
crappy dana 35 question, and 8.8 driveshaft question teejmcd YJ Wrangler Technical Forum 2 12-07-2008 08:50 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
