dana 30 problems - JeepForum.com
post #1 of 14 Old 05-30-2013, 04:14 PM Thread Starter
Cocopebels
dana 30 problems
I'm having problems with my d30. Spins just fine until its locked in. All the small gears turn but the ring and pinion don't turn but 10-15 degrees then it locks up and won't turn any more until the teeth slip on the ring and pinion. What could be causing it to bind like this?
Cocopebels is offline
post #2 of 14 Old 05-30-2013, 04:23 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Can you jack up the axle and spin the front driveshaft?
Luck Favours The Prepared
Anticanman is offline
post #3 of 14 Old 05-30-2013, 04:43 PM Thread Starter
Cocopebels
I don't have access to a jack right now but I'm guessing it won't.
post #4 of 14 Old 05-30-2013, 04:50 PM Thread Starter
Cocopebels
It only does it when the two front tires are locked together. IIvtaken the actuator off and used my fingers to lock and unlock it. So I know for sure its only when both axels are locked together.
post #5 of 14 Old 05-30-2013, 05:40 PM
Louie4
Does the pinion yoke have any slop in it? You may need to crack the diff open and take a look inside.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 14 Old 05-30-2013, 05:58 PM Thread Starter
Cocopebels
Don't know what the pinion yoke is but I can grab it were the drive shaft attaches and it don't have any slop there...
post #7 of 14 Old 05-30-2013, 06:11 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
So with the differential cover off like it was in the picture in the other thread, can you spin the driveshaft one full revolution?
post #8 of 14 Old 05-30-2013, 06:16 PM Thread Starter
Cocopebels
Nope. Lock or unlocked can't turn it by hand. I can tap it around with a hammer.
post #9 of 14 Old 05-30-2013, 06:46 PM Thread Starter
Cocopebels
Could the pinion bearing be messed up and causing this? Carrier bearings?
post #10 of 14 Old 05-30-2013, 07:28 PM
Louie4
Very possible. It looks rusty in there. How was the fluid?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 14 Old 05-30-2013, 07:35 PM
USMCBuckWild
Looks like more rusty water than oil on the gears and the cross pin. I would hazard to guess the bearings are all shot.
Is there shiny particles in the fluid? Kind of look like glitter?
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #12 of 14 Old 05-30-2013, 08:24 PM Thread Starter
Cocopebels
Muddy water pored out when I opened the case. So I'm going to wish it was my transfer case wile I slowly rnr my front diff...
post #13 of 14 Old 05-30-2013, 09:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't bother washing it out if the water was muddy. Bearings are probably toast.
post #14 of 14 Old 05-31-2013, 05:18 AM
Louie4
Based on that you should change all the fluids on your drivetrain...and like Nick said, your bearings are toast.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
