Dana 30 Problem - JeepForum.com
post #1 of 6 Old 09-13-2009, 08:51 PM Thread Starter
Ratmeat
Dana 30 Problem
In the picture below, there is what looks like a splash ring on the binion shaft shaft behind the pinion gear. The splash ring is all chewed up in one area.
The Rig makes a clunk clunk clunk sound when driving and on the gas. I believe this is the culprit.
My questions are:
1) Is this ring needed.
2) Can it be removed without removing the pinion gear
I really don't want to have to reset up preload on this dif, but will if I have to.
Thanks in advance...
Gary
Doing my own thing, and being an individual since 1967!
A veteran is someone who, at one point in his life, wrote a blank check made payable to The United States of America, for an amount of up to and including his or her life. That is Honor, and there are way too many people in this country who no longer understand it.
Ratmeat is offline
post #2 of 6 Old 09-13-2009, 09:24 PM
Louie4
"You pass butter"
Louie4's Avatar
To answer your questions:
1. You'll have to inspect all the teeth on the ring and pinion to make sure they aren't missing a tooth or have been damaged. If you have to get another ring you have to buy them in a set since they are machined to fit each other. If that happens then you will need to set up the backlash and preload. But using the existing shims gives you a good starting point.
2.Yes the ring and carrier can be removed without removing the pinion gear. I would take a picture of the assembly and make sure to keep all the parts in order like they came off the diff. You don't want to install the caps upside down or on the wrong side.
If you're planning on replacing the oil slinger, then yes you will need to remove the pinion because its sandwiched between the pinion head and the inner pinion bearing. Have you turned the pinion yoke by hand to see how it feels and where the problem might be?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 6 Old 09-14-2009, 12:13 AM Thread Starter
Ratmeat
All is well inside except the slinger.
You answered my question though
thanks
Ratmeat is offline
post #4 of 6 Old 09-14-2009, 10:36 AM Thread Starter
Ratmeat
Actually I have one more:
Is the oil slinger needed or can I safely eliminate it?
Ratmeat is offline
post #5 of 6 Old 09-14-2009, 08:18 PM Thread Starter
Ratmeat
Anyone? 10 char
Ratmeat is offline
post #6 of 6 Old 09-14-2009, 08:29 PM
Louie4
"You pass butter"
Louie4's Avatar
You need it. It helps lubricate the pinion bearings. I saw where yours was bent. Do you know what caused it?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
dana 30 problem? timritchieblue TJ Wrangler Technical Forum 11 10-03-2009 08:59 PM
Dana 44 Rearend Problem gotriver TJ Wrangler Technical Forum 12 06-03-2009 05:20 PM
Dana 30 Problem???? bddisi TJ Wrangler Technical Forum 20 12-06-2008 10:00 AM
Dana 35 axle problem Serafim TJ Wrangler Technical Forum 9 07-16-2008 07:33 AM
Problem with Dana 44s in a TJ hoggster TJ Wrangler Technical Forum 6 04-25-2008 11:44 AM
