dana 30 problem - JeepForum.com
post #1 of 14 Old 07-25-2010, 10:16 AM Thread Starter
bigred94
dana 30 problem
ok so i bought new spiders for my dana 30 i pulled the cover 10 minutes ago and was about to chanage them. i noticed that the bolt for the center pin is gone. so now wat this is the sencond one i saw like this. any secert on getting that out?
1994 yj 4.0 5speed, soa 2inch springs,front aussie with tj shafts and 4.10s,8.8 with disc with lsd, on board air,35inch km2s, wj intake,63mm throttle body,costum 2.5 exhuast
bigred94 is offline
post #2 of 14 Old 07-25-2010, 10:54 AM
wheelin
i assume you mean the head of the bolt is sheard off. i have come across that to. i had to use a punch and big hammer to punch the center pin through.
wheelin is offline
post #3 of 14 Old 07-25-2010, 11:07 AM
onlyinayj89
The d-30 only has the pin there is no bolt with it. You need to take a punch the size of the hollow pin and punch it out away from the ring gear toward the spider gears because the hole is slightly tappered.
onlyinayj89 is offline
post #4 of 14 Old 07-25-2010, 11:25 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
I would bet this is the case. I have a set of 4:10 gears with the carrier from an XJ Dana 30 HP that I am putting in the wife's YJ. This XJ set also uses a roll pin to hold the cross shaft in place.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 14 Old 07-25-2010, 04:42 PM Thread Starter
bigred94
yea i didnt want to hear that lol. way to much work to replace spider gears but i guess im gonna do it. so i take out the carrier and remove the ring gear and drive out the pin away from were the ring gear sits?
bigred94 is offline
post #6 of 14 Old 07-25-2010, 07:24 PM
onlyinayj89
Yep you got it, it isn't hard if you have the right diamater punch (or whatever you use) to punch it out.
As long as what you have doesn't sit in the roll pin, if it does it usually gets jammed in the pin and forces the pin to spread open a little (since the pin is hallow), and that makes it harder to get out.
post #7 of 14 Old 07-25-2010, 07:32 PM
jbeebe
x2. it only goes out one direction (hit it down away from the ring gear) and find something (a punch or screwdriver) that is a perfect fit.
jbeebe is offline
post #8 of 14 Old 07-25-2010, 10:27 PM Thread Starter
bigred94
to be honest i dont even want to the 30. i might weld it, i know nott a good idea i do have a posi lock installed works great. i just found a great deal on a mid 80s ford hp60 for 300 kinda cant beat that.
bigred94 is offline
post #9 of 14 Old 07-26-2010, 06:05 AM
jbeebe
that's a pretty big diff for only 35's though. have you thought about a full width 44?
and don't weld the d30 if you drive it on the street at all
jbeebe is offline
post #10 of 14 Old 07-28-2010, 10:11 PM Thread Starter
bigred94
well if i run 60s im gonna strech the rear and most likly run 37s or 38s. and as for welding the 30 i have a posi lock so it will be the same as if i had a locker.
bigred94 is offline
post #11 of 14 Old 07-29-2010, 06:37 AM
jbeebe
wrong. a posi-lock is not a locker. if you weld it it will be like having a spool.
lockers are made to either be shut off, or automatically be off during regular use. When you go around turns one wheel must rotate faster than the other, this is what causes a clicking sound in some automatic lockers. But if you weld your gears, it will be like always having your ARB turned on, or having your automatic locker not "give" around turns. no good for on road use.
jbeebe is offline
post #12 of 14 Old 07-29-2010, 07:37 AM Thread Starter
bigred94
Ok I never said a posi lock is a locker. I'm pretty sure I know what it does. It replaces the vac cad unit. So there for if I weld my spiders as long the posi lock is disingaged only the drivers side tire will spin .
bigred94 is offline
post #13 of 14 Old 07-29-2010, 02:50 PM
jbeebe
i apologize, as i read your last post wrong. I agree, with the CAD disengaged and your spiders welded, you will be fine.
jbeebe is offline
post #14 of 14 Old 07-29-2010, 02:59 PM Thread Starter
bigred94
Yea its only gonna be a temp fix for now untill I get a new front end.
bigred94 is offline
Dana 44 ARB problem Hotrod97z TJ Wrangler Technical Forum 4 05-12-2010 02:25 PM
dana 30 problem? timritchieblue TJ Wrangler Technical Forum 11 10-03-2009 08:59 PM
Dana 30 Problem Ratmeat YJ Wrangler Technical Forum 5 09-14-2009 08:29 PM
Dana 30 Problem???? bddisi TJ Wrangler Technical Forum 20 12-06-2008 10:00 AM
Problem with Dana 44s in a TJ hoggster TJ Wrangler Technical Forum 6 04-25-2008 11:44 AM
