Dana 30/powertrax no-slip install problem - JeepForum.com
post #1 of 3 Old 01-09-2010, 10:50 AM Thread Starter
JeepinSC87
1987 YJ Wrangler
Upgrading my Dana 30 in my 87 YJ with 4.56 gears and a powertrax no-slip locker. Because of the low gear ratio I am forced to remove the differential case and ring gear in order to get the cross shaft out; meaning I have to install the powertrax locker before I can install the new ring gear and put the diff. case back in the axle housing.
Now to the question....when removing pass. side inner axle shaft I first had to remove a c-clip from the end of the axle shaft inside the diff. I've read many threads saying the D30 has no c-clips. I've also read a few saying if there is a c-clip to just discard it. Because I have to install the powertrax before putting the diff. case back in the housing, I cannot get the c-clip back in. I don't want to just throw the c-clip away without a solid answer. Has anyone ever had this problem? If so, what did you do about it? Thanx in advance.
Matt
'87 White YJ 4" RE suspension lift 2" performance accessories body lift Tom Woods CV driveshafts and SYE AX15 conversion 8.8 rear axle with l/s Dana 30 front axle with Powertrax No-Slip Traction System 35x12.50 Mastercraft C/T's WeBeR CaRbUeRaToR! KC Lighting
Doesn't it sound sexy?
JeepinSC87 is offline
post #2 of 3 Old 01-09-2010, 10:59 AM
Apollo12227
I havn't personally installed a powertrax system in my jeep... However, my dana 30 doesn't have clips... Upon taking the wheelbearing/hub off, my axle pulls strait out of the carrier. If you look at how the axle assembly is put together, there is no way the axle is going anywhere BECAUSE of the fact you have a hub assymbly...
Now, if you wern't a 4wd vehicle, or if we were talking about the rear (excluding non-clip axles) then you WOULD need C-clips because there is nothing there to gold the axle into the differential... Meaning your axle, drum, and tire would take off into the woods and leave you sitting on 3 or less tires lol. Simply put, your wheel bearing/hub assymbly is responsible for keeping the axle firmly seated inside the carrier spline.
Personally, if it were me, I would install without and store them for safe keeping just in case... But as stated before, I have a Cherokee one piece conversion and neither the cherokee, my stock, nor the drivers side axles had a c-clip on them.
Apollo12227 is offline
post #3 of 3 Old 01-09-2010, 11:04 AM Thread Starter
JeepinSC87
1987 YJ Wrangler
apollo,
Thanx for the input but herein lies the problem: I have a front axle disconnect system (vacuum disconnect), therefore the inner axleshaft is just floating between the diff. case and the vacuum disconnect collar. Isn't this c-clip the only thing retaining the inner axleshaft from moving around too much?
Also, just looked in my haynes manual. It also mentions the c-clip under the section for removing the axle shafts.
PowerTrax No-Slip dana 30 front Bivouac TJ Wrangler Technical Forum 12 03-08-2008 08:54 AM
write-ups for powertrax no-slip/lockright install D30/D44 kcphilaflyer TJ Wrangler Technical Forum 3 03-17-2006 11:54 AM
Powertrax No - slip front 30 install ? psl53 TJ Wrangler Technical Forum 4 03-04-2006 06:06 AM
Dana 44 Powertrax No Slip jrtdogbone TJ Wrangler Technical Forum 6 02-14-2005 11:00 PM
Aussie VS. Powertrax No Slip for front Dana 30? sbninja TJ Wrangler Technical Forum 5 10-17-2004 04:31 PM
