Dana 30 "Lockright Locker" shaft C-Clip Locker? - JeepForum.com
post #1 of 3 Old 03-11-2010, 07:56 PM Thread Starter
clarkjdg
clarkjdg's Avatar
OK I'm putting a lockright locker in my Dana 30 and new 4.10 gears useing the " JEEPSONLY" write up on "Dana 30 Front Lockright Locker" I have followed everthing in the write up except one thing. I have got it totally torn down and at the first they are telling that they have two ways to pull the the cross shaft out one is by grinding 2 to 3 teeth down enough to pull the pin, or by pulling the ring gear, well I have pulled the ring gear the same way they did, and at the bottom they are showing the complete Locker/Carrier assembly and it is ready to go in and the pin is in and the ring gear is on so here is what has got me scrathing my head " How did they put the C-Clip Lock back on the shaft with it totally assembled there isnt any room to reclip the shaft. So I'm asking for someone who has been there to help me figure this on out because the only thing that I can see is that they didn't put the C-Clip Lock back on and my head is getting very tired of me scratching it?
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #2 of 3 Old 03-11-2010, 09:01 PM
TheRealOldjeep
You don't put the c-clip back on. The factory only used it to make assembly easier, it's not needed.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #3 of 3 Old 03-11-2010, 09:07 PM Thread Starter
clarkjdg
clarkjdg's Avatar
THANK YOU !!!!!!! I figured that was it but wanted to make sure.
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
clarkjdg is offline
Dana 30 with ARB locker qurstion "FLUID" gottkts YJ Wrangler Technical Forum 6 01-23-2010 11:38 AM
Powertrax Lockright locker for the Dana 30, have some ??? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 17 10-07-2009 10:11 AM
Dana 30 Lockright Locker Problem Chris @ GATR TJ Wrangler Technical Forum 12 04-20-2007 10:04 AM
lockright locker in a dana 30 bryan-2kevo YJ Wrangler Technical Forum 11 04-13-2006 12:29 PM
98 sahara with dana 35 rear. Which locker kit? Is it a "C" rupert14 TJ Wrangler Technical Forum 8 09-05-2003 10:55 AM
