dana 30 high steer knuckle - JeepForum.com
post #1 of 12 Old 03-09-2013, 04:40 AM Thread Starter
mikes95YJ
hey everyone! im looking for a dana 30 high steer knuckle. just the knuckle its self. i found teraflex's which is $423. wondering of any other places to look for them, any help would be awesome! thanks
ps- using a SOA
mikes95YJ is offline
post #2 of 12 Old 03-09-2013, 05:53 AM
timatoe
timatoe's Avatar
I haven't looked into it too much because any Jeep in a salvage around here is gold or at least they think so when it comes to pricing, but I believe you can swap the knuckles from a Grand Cherokee.
I'm sure someone here has done it or can at least give you the correct info on it.
timatoe is offline
post #3 of 12 Old 03-09-2013, 06:14 AM
Cobra Jeep
You can use the 99 and up WJ Grand Cherokee knuckles. Just do a search and you should find a few write-ups.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #4 of 12 Old 03-09-2013, 06:57 AM
Louie4
Here's a parts list.
http://www.jeepforum.com/forum/f11/w...-list-1216365/
I am running a Teraflex knuckle but I got it used for a good price. The guy also threw in a HD tie rod and drag link.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 12 Old 03-09-2013, 07:23 AM
soonermatt
I just did high steer with junkyard parts. It ended up costing around $200. I also replaced unit bearings, brake rotors, master cylinder, booster, calipers, tie rod and drag link though. $200 includes everything. Knuckles were $10 each.
It came out pretty good if I do say so myself:
Google "WJ knuckle high steer". You'll have to get 99-04 WJ knuckles and their brakes. You'll want to take their better master cylinder, tie rods and drag link. I did a tie rod flip for clearance. I had to shorten the drag link which you can read about in my build thread. You'll need to $20 JKS spacers between the unit bearing and knuckle. And you can buy mid 90s Crown Vic rotors. You can be a snob about not buying used rotors....or you can go to the junkyard and see all those grandma Crown Vics with no miles. It was funny.
soonermatt is offline
post #6 of 12 Old 03-10-2013, 09:51 AM Thread Starter
mikes95YJ
I found a kit locally that is teraflex. For $500, should I jump on that or go to a junkyard for the wj knuckle?
post #7 of 12 Old 03-10-2013, 10:36 AM
jsawduste
2006 YJ Wrangler
You should do this
http://www.mountainoffroad.com/_e/Je...e_87_95_YJ.htm
Then search on my user name for more steering info.
jsawduste is offline
post #8 of 12 Old 03-10-2013, 10:46 AM
RockWoRM
RockWoRM's Avatar
I think that would be up to you and how much mech skills you have. If you have the time and knowledge and a local yard with the parts that arn't gold plated, then you could go that route. And although it has been years... IIRC, quite a few guys were having issues with the Tera setup back then. Not sure about now.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #9 of 12 Old 03-10-2013, 04:06 PM Thread Starter
mikes95YJ
Scored the kit for $450. I'm in a little bit of a rush to get this project done before I graduate, but all the help is much appreciated!
post #10 of 12 Old 03-10-2013, 08:46 PM
Louie4
WRM
I heard the main issue was the aluminum hex drag link and tie rod being weak. I believe the knuckles were solid, well at least the one I'm running is. I put some inserts in it to flip the tie rod and drag link for clearance. So far so good.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #11 of 12 Old 03-10-2013, 09:01 PM
plym49
Attachment 581423
Yep, it does indeed look pretty good! Nice job.
plym49 is offline
post #12 of 12 Old 03-11-2013, 02:23 AM
fratis
fratis's Avatar
i had the tera knuckle and id go the WJ route. the only problem with the tera knuckle is they made the draglink arm too long. you have to redrill your own hole closer to the ball joint.
-insert meaningless out-of-place political diatribe-
fratis is offline
