Dana 30 Front Hub "Shim"? - Page 2 - JeepForum.com
post #16 of 17 Old 08-13-2011, 04:54 AM
1tuffyj
Can someone tell me how he's getting those 3 bolts in straight with the unit bearing cocked at an angle?
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
post #17 of 17 Old 08-13-2011, 06:26 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
those shims are only for the larger old style axles with real spindles and hubs. d44 and d60's.
d30's use adjustable ball joints.
ratmonkey is offline
35" tires with front dana 35 justjeepinorfw JK Wrangler Technical Forum 8 08-01-2011 01:08 PM
Which front drive shaft did you use for 2" suspension + 1" BL 1" MML, and Tummy Tuck? awalp TJ Wrangler Technical Forum 23 05-16-2011 10:24 PM
Installing SYE - How much axle shim to use? (4" lift) Mark_ZZ3 YJ Wrangler Technical Forum 8 09-11-2007 10:30 PM
4.5" RE shim ?'s Nater018 YJ Wrangler Technical Forum 7 10-26-2004 10:41 PM
Where can i get a HP Dana 44 front, and a ford 9" rear, w/ same width+lug pattern? jeepcj7 TJ Wrangler Technical Forum 7 11-25-2003 02:54 PM
