Dana 30 Disco help - JeepForum.com
post #1 of 5 Old 04-11-2010, 08:27 PM Thread Starter
divewall14
2003 WJ
Dana 30 Disco help
hi i have a 95 yj with the Dana 30 disco and i was wondering if there is anything special i need to do to pull the passenger side axle shaft cuz i need to do the U joints.
thanks for the help
divewall14 is offline
post #2 of 5 Old 04-11-2010, 08:29 PM
93jeepyj
just make sure its in 2wd and you shouldn't have any issues. theres just a splines collar in there that slide back and forth to engage or disengage the shafts.
93jeepyj is offline
post #3 of 5 Old 04-11-2010, 08:30 PM
Louie4
No, not really. You'll need a 12 pt 1/2" socket though to get the three hub bolts off and a 36mm socket for the stub shaft nut.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 5 Old 04-11-2010, 08:34 PM Thread Starter
divewall14
2003 WJ
yeah i have all the nesicites but i guess i am asking....is there anything that holds the shaft in the disconect thing that i need to remove in order to pull the shaft?
post #5 of 5 Old 04-11-2010, 08:41 PM
ritjobbie
Nope, it'll just slide right out. 13mm 12-point socket, three bolts, pull.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
dana 44 wagonner axle swap, vacuum disco joe's_yj YJ Wrangler Technical Forum 2 06-30-2008 02:47 PM
which disco? Hesher420 TJ Wrangler Technical Forum 17 03-04-2008 12:31 PM
JKS Disco help Rocky5 TJ Wrangler Technical Forum 4 08-06-2007 10:12 AM
Dana 30 Disco axles boise49ers YJ Wrangler Technical Forum 2 01-22-2007 09:11 AM
hp30 disco to non-disco conversion Bucket110 TJ Wrangler Technical Forum 2 06-22-2005 02:46 PM
