Dana 30 Build to handle 35" or 36" - JeepForum.com
post #1 of 27 Old 09-16-2011, 05:16 PM Thread Starter
dougbrown
Hi Guys,
I want to put a Ford 8.8 in the rear with 4.10 I thing. I know I want the Ford 8.8, Just not sure if I want the 4.10. So Now at the same time I want to think about building a front axle to handle 35" or 36". I don't plan on running them till my new 33" are shoot or about a year from now. What I do want is to be ready for the swap.
So What do I need to do to make my 35 be able to handle them?
I was thinking about an ox cable locker or detroit locker. What I'm not so sure about was the half shaft holding up. Right now I have the washer stack in mine.
Thanks Doug.
dougbrown is offline
post #2 of 27 Old 09-16-2011, 05:19 PM
justanotherjpr
What kindof wheeling do you do? When you say 36", I am assuming you mean a bias ply tire like an IROC - is that correct?
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 27 Old 09-16-2011, 05:20 PM
2doorxj
2doorxj's Avatar
Ox locker, alloy shafts, and id say you'd be good for 35s, for 36s, I wouldnt use a 30 but, if u insist, truss it, rcvs, warn hub conversion, and a light foot.
2012 Cherokee of the Year
2doorxj is offline
post #4 of 27 Old 09-16-2011, 05:34 PM Thread Starter
dougbrown
I trail ride in drit and mud. Not to much rock, some hill climbing.
If I don't use a dana 30 what are my other options? This jeep stuff new to me!
post #5 of 27 Old 09-16-2011, 05:42 PM
dillonjm
2013 WK
The HP D30 is fine for 35's in its stock form.
I wouldn't have any issues running a TJ LP D30 with 35's and the HP is stronger by design (gear wise). IF I wanted to upgrade, I'd put a locker and TJ shafts into it (for the larger joint) and call it a day.
36's are on the upper limit of what I'd run, 37's are too big. 37's are almost too big for a stock 44 IMHO.
Temper my opinion with the fact that it all depends on your wheeling style/environment/type.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #6 of 27 Old 09-16-2011, 05:53 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
I ran 37x14.50s with a 4.3 Atlas, 4.88's and a healthy 4.3 Chevy in my old YJ.
The front 30 did fine, after I swapped to 30 spline shafts and Yukon Superjoints.
I ran ARB lockers in both the 8.8 and the HP30 and everything did great.
Never had any breakage after swapping over to the Yukon U joints, but before they went in I could break a Dana U joint at will (larger U joints with 27 spline chromo shafts).
I would keep you eyes open for guys selling good stuff for cheap.
I wheel in rocks, so am no doubt a little harder on stuff than you would be by the sound of it.
Just remember a complete imbecile can destroy a built Dana 60, so careful driving makes everything last longer. Joe Dillard also had a built Dana 30 in his rig, and he wheels some pretty severe stuff and had a 5:1 Atlas to boot. He never had a problem IIRC.
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #7 of 27 Old 09-16-2011, 05:54 PM
hesserdude07
i run 35s on my stock front axle with a lock rite in it. And im waiting on my 37s since they are back ordered... When i bump to 37s, im going to do chromo shafts.
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #8 of 27 Old 09-16-2011, 06:26 PM
'92 vegas YJ
I just went out for my first time with 35s on the 30 about two weeks ago.
I snapped a driver side u joint and broke the stub ears off the shaft....
Might need at least chromos and some good joints...
~'92 YJ with many upgrades and many more calling my name..... it never ends
~'07.5 Dodge Ram Megacab 2500, 6.7L Cummins turbo diesel
April 2012, May 2013, May 2014 YJ of the month
My one ton YJ unlimited build
'92 vegas YJ is online now
post #9 of 27 Old 09-16-2011, 06:33 PM
95wrangler4life
I run 36's TSL SX's on my HP30 with 4.88s and a aussie on stock shafts in the rocks hard and no real issues as of yet. I do plan that once I break a shaft I will be doing Chromo's...
The problem with CTM's and RCV's is you are wasting money... not you are taking all the stress from your u joint and putting that into the ring gear/pinion which will not tolerate that much of it.... I'd rather snap a $15 u joint that destroy my internals... Even when i switch to Chromo's I will not be going with CTM's.... Now if your rocking a Dana 44, 60 or bigger up front, the ring gear and pinions are able to handle more so the CTMs or RCV's are a great purchase.
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #10 of 27 Old 09-16-2011, 06:36 PM
95wrangler4life
can i ask a ? without it sounding d*ck? I put a locker in my front on 33's and did the exact same thing my 1st trip out, mine was lack of knowing WTF i was doing with having the front locked.... Like I said since then I have moved to 4.88s, aussie and 36's and wheel it in the rocks without issues so far!
Build thread:
post #11 of 27 Old 09-16-2011, 06:39 PM
leftlanetruckin
XJ on 37's
All well and good until you break a $200 chromo shaft due to that $15 U joint you left in there as a weak link.
I have, and continue to know lots of folks who wheel hard on HP30's, and have YET to see a R&P give way. Now granted these folks are experienced and stop when the bouncing starts, but still......
After I installed the 4.3 Atlas, I would break U joints at will. The last U joint that went screwed my chromo shafts and chipped a tooth on the R&P due to the sudden shock. After the 30 spline shafts and yukon superjoints went in, never had a single issue.
Take it for what it's worth, but I speak from personal experience and not what I heard etc
The tales of R&P blowouts in a HP30 are so over blown it isn't funny any more.
Martin
post #12 of 27 Old 09-16-2011, 07:32 PM
'92 vegas YJ
I wheeled for many years hard in the rocks on 33s with a stock 30 but first trip with 35s I broke, could be a coincidence
I do have a really heavy right foot though
post #13 of 27 Old 09-16-2011, 07:46 PM
MLJeeper
MLJeeper's Avatar
Ive been running 35s on my HP30 with 27 spline chromos for 5 years or so now. With the chromos, locker and 35s I have snapped one stub , one shaft and twisted the splines on another. I do not think thats too bad considering the abuse its seen.
If I had the 30 spline shafts as leftlane is suggesting, I would of Probably had no issues with just 35s. I do agree with 95wrangler4life on the RCVs though, that is a lot of money to invest in a Dana 30. Their shafts are excellent but there are better investments if you are going to drop that kind of coin. The HP30 is well designed but it IS a light duty axle.
For those running the stock shafts, I did find that a tack weld between the ujoint/collars stopped the collars from getting nuked when the u-joint gave. YMMV
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #14 of 27 Old 09-16-2011, 07:49 PM Thread Starter
dougbrown
So what year tj dana 30 shaft do I need to do away with my half shaft?
post #15 of 27 Old 09-16-2011, 07:55 PM
RockWoRM
RockWoRM's Avatar
Originally Posted by dougbrown View Post
Hi Guys,
Thanks Doug.
what is your budget? there's a ton a stuff you can do to pollish a D30. but the weakest link, as Martin pointed out, are the ujoints. when I went to 35's, I upgraded to new stock '95 shafts w/x760 ujoints... carry the old joints/shafts as spares. I also have a locker and I wheel it purdy hard. has worked fine to date. if you're looking to not spend a ton of $$$, then you could swap in a new YJ driver side and a TJ pass side, and get rid of the vac/2 piece and gain the big ujoints all at the same time. a little more $$ and upgrade to chromos. also, good quality R&P is not a bad idea, either.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
LJ Build "Sylvia" another stretch on tons, COs, Hemi Swap-- EVENTUALLY VecoPlan TJ Wrangler Technical Forum 322 11-18-2013 09:20 AM
Stock jack handle + extension arm "lost". JeepingGinga TJ Wrangler Technical Forum 1 09-07-2011 11:45 AM
The "One-Millionth" Can My Jeep Handle 35's? JeeperFound TJ Wrangler Technical Forum 15 07-12-2010 11:41 AM
need the "seat forward" knob / handle thingy CB4 TJ Wrangler Technical Forum 5 12-02-2007 02:48 PM
Help Deciding "how" to build my dana 44 and dana 60 Big-n-Broke-YJ YJ Wrangler Technical Forum 5 08-12-2006 06:03 PM
