Dana 30 Bearings - JeepForum.com
post #1 of 13 Old 07-19-2004, 06:49 AM Thread Starter
Meister_jeep
Dana 30 Bearings
Does anyone have the bearing numbers that go in the dana30? I will be changing them and need the numbers for them before I take it apart. It goes with 4.10 gears (I have no idea if they are different in the 4.10 then the 3.07's)
1988 YJ 4.2l
__________________________________________________ __
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
FORD 8.8 WITH 4.10 GEARS, DISK BRAKES
33x12.50 GOODYEAR MT/R's ON AR767 15x8
CUSTOM STANLESS STEEL DISCO`s
JUICEBOX.
LED TAIL LIGHTS
$10 homemade POSILOCK
(IN THE WORKS THIS SUMMER)
-Custom front and rear bumpers
-HEI UPGRADE
-4.0 HEAD
-MIGHT TRY THE JEEP INJECTION KIT FROM WEBER
Meister_jeep is offline
post #2 of 13 Old 07-19-2004, 02:39 PM Thread Starter
Meister_jeep
Anyone Has This Info?
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
post #3 of 13 Old 07-19-2004, 04:27 PM
TSEJEEPERS
What bearings do you need? The pinion bearings? Carrier bearings? or the front hub, which is a sealed unit and will have to be replaced as a whole unless you have lockouts.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 13 Old 07-19-2004, 08:24 PM Thread Starter
Meister_jeep
both the carrier bearings and the pinion bearings
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
post #5 of 13 Old 07-19-2004, 09:53 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
Going by what i see in the dealer's software:
For the pinion:
J812 4052
J812 6499
For the Carrier
J812 6500
you'll need 2 of that one.
if you need the hub bearings as well then
5300 0238
TSE, prior to 91 the hub bearings were not sealed as a unit so he should be able to repack them.
I don't know how current these numbers are but they should be able to cross reference them to the right parts.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #6 of 13 Old 07-20-2004, 06:40 AM Thread Starter
Meister_jeep
i ACTUALLY NEED THE REAL BEARING NUMBERS NOT THE DEALER NUMBER CAUSE i DON'T FEEL LIKE PAYING 3 TIMES THE REAL PRICE CAUSE THEY COME FROM THE DEALER. DOES ANYONE HAVE THE ACTUAL BEARING NUMBERS?
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
post #7 of 13 Old 07-20-2004, 08:01 AM
JRobert
most parts stores can cross reference the numbers.
JRobert is offline
post #8 of 13 Old 07-20-2004, 08:27 AM
coolhand
coolhand's Avatar
No need to yell! just call Randy's Ring and Pinion and order a "Master OverHaul Kit". It will come with everthing you will need. You can also get all tools that your going to need to properly setup the gears. HTH
"The Empty Pocket Warriors." Member #2
"92 YJ, 3.5" BDS. Custom 1.5" lift shackles, 2" BL, Ford 8.8 W/Trac-loc & 33" TrXus MT's (for now).
"No one ever accused the Wrangler of being comfortable, quiet, or practical. No one ever called it boring, either. The Wrangler is a two-door toy, ... great fun to drive with the top down." -- AUTOMOBILE MAGAZINE, March 1995.
coolhand is offline
post #9 of 13 Old 07-20-2004, 10:28 AM Thread Starter
Meister_jeep
sorry for the caps but the system I use here at work is case sensitive. The whole reason I don't want to order an overhaul kit is because you pay 3-4 times the price of the bearings in those kits. I can get bearings here at a cost price so I need the actual bearing numbers
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
post #10 of 13 Old 07-20-2004, 01:55 PM
gigihurt
gigihurt's Avatar
Maybe you should call your local napa parts store and tell them you need the frickin bearings then or just the numbers and see what they say.
gigihurt is offline
post #11 of 13 Old 07-20-2004, 08:41 PM Thread Starter
Meister_jeep
finally found them by myself. Guess you ain't never better server then by yourself. And by the way napa and autoparts stores usually don't give you the numbers cause they know what you are going to da and thats buy it somewhere else.
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
post #12 of 13 Old 07-21-2004, 09:32 AM
coolhand
coolhand's Avatar
I think it's worth it to get everthing you will need all put together in one nice little kit. By everything I'm talking about All four Bearings, New shims for the Carrier and Pinion, new alxe and pinion seals a new pinion nut lock-tite and gear marking compond.
If you don't think all that stuff isn't worth 50 or so bucks then you must be pretty cheep.
coolhand is offline
post #13 of 13 Old 07-21-2004, 01:23 PM Thread Starter
Meister_jeep
I won't waste time with you cause its just going to go on and on. I have everything I need in twice the quality you will get in a kit for half the price. As for cheap think what you want but I have a jeep and I spend much more then I should on it.
1988 YJ 4.2l
WEBER CARB
NUTTER BYPASS
FIBERGLASS BODY TUB
BDS 3.5
SYE+CV SHAFT
JUICEBOX.
LED TAIL LIGHTS
-HEI UPGRADE
-4.0 HEAD
Dana 35 Bearings Shot jason0heman YJ Wrangler Technical Forum 17 01-21-2010 02:01 PM
Can you replace the spindle bearings on dana 30? 02tjsport TJ Wrangler Technical Forum 2 01-30-2009 03:50 AM
Dana 35 Axle Bearings ??? usmctadpole YJ Wrangler Technical Forum 1 01-25-2009 01:36 PM
Dana 44 Axle Bearings JeepRocks86 TJ Wrangler Technical Forum 5 12-03-2006 12:26 AM
? redoing bearings in the dana 35 farmer-dave TJ Wrangler Technical Forum 1 08-15-2005 08:03 PM
