damn lights not working again - JeepForum.com
post #1 of 3 Old 08-17-2011, 03:12 AM Thread Starter
tankinyj
i understand this is a reocurring problem with YJ's. however i thought i just fixed this last week. my front headlights and yellows work fine. however my drivers/passengers side flashers arent working and my rear brake lights arent working AGAIN. we just got alot of rain here too. my passengers side rear light is on when i turn the lights on, drivers side i get nothing, however when i hit the brake the light goes out. when i hit the brakes i get no red but only white as if reverse is on (i actually thought the comp knew to throw the reverse lights on when im backing up without it in reverse such as a hill)
hints? tips? i cant figure this one out
tankinyj is offline
post #2 of 3 Old 08-17-2011, 04:40 AM
Mark05059
its a ground problem. Clean all the mounting surfaces where the rear lights mount. Consider running a ground wire from one of the mounting studs on the light to the frame (nicely cleaned to bare metal)
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 3 Old 08-17-2011, 06:29 AM
Louie4
I agree with above to check first. The last time I had this happen the long plug on the steering column under the dash wasn't pushed in good enough. It caused my left turn signal not to work and even the brake lights though I had running lights and headlights. I was install my A/C unit back in and I think I snagged the wires and partially pulled out the plug.
One thing to try is to just reach your hand under the dash and grab and move around wires to see if the turn signals come back on. That's how I figured out my problem.
Just a thought.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Brake Lights not working...all other lights work Dashash TJ Wrangler Technical Forum 15 12-28-2016 02:20 PM
02 Wrangler Right Front Blinker, Marker lights and Fog Lights not working brianwinchell TJ Wrangler Technical Forum 13 09-12-2012 12:54 PM
NO working lights Custis YJ Wrangler Technical Forum 10 11-20-2010 06:23 PM
TJ Dash lights, and other interior illum lights not working kells81 TJ Wrangler Technical Forum 2 02-22-2010 10:05 AM
Brake lights not working but running lights fine snaustin09 YJ Wrangler Technical Forum 4 11-24-2008 01:22 PM
